Hi everyone,
So I decided to try the turbo out and not 100%sure I want to stay with it but will give it a few more days until I have it set up the way I like.
How do you create bubbles or folders on a screen to hold multiple apps? I dragged them I them on top of each other but that does not work. For instance I have about 10 people on direct dial and drop them into one bubble. I usually used Nova on my other phones but figured I try sticking with stock for a few weeks since its been awhile with a moto which is close to stock.
Thanks for any help
Thanks for any help
