1. Mattsg430's Avatar
    Anyone else experiencing overheating issues with the turbo? Maybe the battery just needs to run through a few more cycles, but it seems to heat up pretty quickly while using it for surfing the web, texting, etc. Usually hovers around 105 operating temp according to GSam battery monitor while doing regular phone stuff.
    Let me know your thoughts. Thanks
    11-07-2014 06:27 PM
  2. Danny1Bears3's Avatar
    Don't worry about it. The phone is designed to handle these temps. The phone cools significantly after it gets to 75% so its not really a big deal.
    Turbo-Shot from my Ballistic Turbo
    11-07-2014 07:20 PM
  3. Mattsg430's Avatar
    Thanks for the reply Danny!
    11-07-2014 07:54 PM
  4. Codger1212's Avatar
    Yeah, but lately not so much.
    11-07-2014 10:05 PM
  5. bizzyqu's Avatar
    125.6 F while turbo charging right now...
    11-07-2014 11:07 PM
  6. Mattsg430's Avatar
    Yikes
    Sent from my Droid Turbo
    11-08-2014 11:19 AM
  7. datagrrl's Avatar
    I get high temps while Turbo charging and using Google maps for navigation.
    11-08-2014 11:46 AM
  8. oldDummy's Avatar
    My understanding is it's common among higher spec'd quad-cores.
    Anand did a article about it .... pre-Apple, so quite awhile ago.
    11-08-2014 12:42 PM
  9. psf57's Avatar
    I know this is an old thread, but here goes. Took a little trip and half way through my regular GPS kicked the bucket, so got the turbo out and started google maps. (had 2 hours to go on trip) within 45 minutes, received a notification that phone was overheating, 108.5. (From Gsam) What is the highest tolerance for temps for this phone? Chatted with Motorola and they claim......they don't know. It's the Ballistic nylon version, had a thin plastic case on, even took that off.
    04-26-2015 08:00 AM
  10. Toes Up's Avatar
    psf57, I wish I had a good answer for you but I don't. That said, I doubt hitting that temperature once or even occasionally is going to be a problem. My phone regularly hits 100°F on the Tylt Vu charger just about every night and I've wondered if that temperature is eventually going to be a problem for the battery.
    04-26-2015 08:37 AM
  11. I800C0LLECT's Avatar
    I know it's different but I'm a huge fan of CPU design and implementation with computers.
    Our phone hardware should be much more robust than a computer processor. Those are designed to throttle back when they hit thermal limits.
    I promise our phones are not only designed to throttle back and limit processing power to limit and control thermal overhead but they're also very far from those limits at 100 Fahrenheit. Processor and hardware designs can easily handle 165.
    The battery? I can't comment on because I don't know much about them
    04-26-2015 12:57 PM
  12. matthewallen31315's Avatar
    my phone was charging and i go to check on it and it wont turn on. i know its on but the screen is black with colors and the screen didnt break. please help
    04-19-2016 03:17 PM
  13. doogald's Avatar
    Press and hold the power button for about 10 seconds or so, until you see the phone restarting. (This is how Motorola designed it to do a virtual removal and replacement of the battery when they started selling the Razr with a non-removable battery.)
    04-19-2016 03:51 PM
  14. beeztrain's Avatar
    My phone almost always over heats when connected to Bluetooth. Basically, after a few minutes it freezes and becomes unusable. It's extremely annoying and really the only reason I'm considering dumping this phone for a new one.
    04-25-2016 07:56 AM
  1. Why is my Samsung Galaxy Note 4 overheating so much?
    By Chi Hyun Ahn in forum Ask a Question
    Last Post: 04-10-2016, 09:13 PM
  2. Should overheating crack my phone screen (S5)?
    By brittyann21 in forum Samsung Galaxy S5
    Last Post: 11-05-2014, 06:35 PM
  3. Camera not working, static through speakers and overheating.
    By reflectivenight in forum HTC One Mini
    Last Post: 10-28-2014, 12:30 PM
  4. Should I get a new battery if my phone is overheating?
    By Joe Kim in forum Samsung Galaxy S5
    Last Post: 10-28-2014, 01:46 AM
  5. Replies: 2
    Last Post: 10-23-2014, 12:08 PM
