1. Littlejoe919's Avatar
    I'm too new to post links ;-( , but I found this over on XDA. Search on You Tube for the posts title (minus the you tube). It's by AndroMJB.
    Hope it helps someone.
    mightyfacundo likes this.
    11-07-2014 07:21 PM
  2. dungoyle's Avatar
    Here you go Joe. Is this it?
    Littlejoe919 and dmmngs2 like this.
    11-07-2014 07:24 PM
  3. Littlejoe919's Avatar
    Thanks Dungoyle, that's it.
    11-07-2014 07:32 PM
  4. mightyfacundo's Avatar
    I like the Moto suite but I have disabled them, as described in the video, to see how significant the difference in battery life is. Thanks for the link.
    11-07-2014 09:15 PM
  5. ckelly33's Avatar
    Let us know how that works out!
    11-08-2014 12:08 AM
  6. dungoyle's Avatar
    I kept some and disabled others:
    • Assist: Sleeping and Driving are on.
    • Actions: Approach for Moto Display is on -- this I use too much to leave off, and maybe why I don't have a loose power button?
    • Display: Moto Dusplay is on (I think this is also referred to as the "breathing" feature). Another "too valuable to lose" feature for me.
    • Voice: OFF. Ultimately, I decided I don't need Moto Voice AND OK Google. I can say OK Google from any page on my phone. I may be missing out some of the moto-specific phone commands, but for now, I can live with that. I want to see if turning some of these features off do in fact yield better battery results.
    11-08-2014 06:58 AM
  7. beeare's Avatar
    Even without approach for moto display, if moved, or if you have a notification, you do not have to use the power button. Although I love this feature, I think there's a good chance this one is causing battery drain since it uses the sensors on the front of the phone.
    11-08-2014 10:53 AM
  8. mightyfacundo's Avatar
    I will report back tonight, but so far so good.
    11-08-2014 02:44 PM
  9. mightyfacundo's Avatar
    Well, I did everything the video suggested, and I can say that it definitely makes a difference in battery life. I've gone 16 hours off the charger with 3.5 hours of sot, and my battery is at 59%. Today was a fairly moderate use day, with a few hours of tethering while at the soccer field, some browsing, a few phone calls, texting, a 2:30 4K video recording, played some Knights and Dragons, watched an episode of The League using TV Portal, and watched about an hour and a half of the Auburn-A&M game using SlingBox. K&D and SlingBox are serious battery killers, so I'm pretty happy with the battery life today.
    HOWEVER,
    I haven't had a problem going an entire day since I bought this phone, regardless of what I've thrown at it, and to be honest, turning off all of those things took away my enjoyment of the phone. I like all of the Moto Apps, and they're a good part of the reason why I like this phone. Since battery life isn't a concern, I have turned everything back on, but it's good to know that if I get into a situation where I really need to maximize my battery, I now know how to make it happen.
    ckelly33 and Littlejoe919 like this.
    11-08-2014 10:52 PM
  10. ckelly33's Avatar
    Yeah, the Moto features kept me with this phone over the G3. I don't care to lose them and, like you, I don't really NEED to. A 24+ hour battery would be cool but I'm just fine to charge it during the 7 hours that I'm asleep. I have never needed (yet) more than 16-18 hours of more than typical use that the phone has been giving me.
    11-08-2014 10:57 PM
  11. Snareman's Avatar
    That video has some nice idea, but geez, I get a phone with a mongo battery and all of these cool features and I have to disable them all to get to anything close to the purported battery life? I know... its all advertising crap to make me thing this phone has sweet battery life. The battery life is most certainly worse than my Maxx was.
    mr2sweet likes this.
    11-09-2014 02:38 AM
  12. mobrules's Avatar
    I follow most of the ideas in the video and have been for awhile. The settings are not for everyone but it works for me. I only post this to show how far it can go if set up that way. I don't have a lot that sync's in the background but it does when the screen is active. I probably check it on average of 5-7 times per hour, except while sleeping. I started out using the app auromateit but switched to tasker. I just like tasker a little better.
    Attached Thumbnails Droid Turbo battery options - You Tube-1415545947114.jpg
    11-09-2014 09:17 AM
  1. Replies: 38
    Last Post: 12-04-2016, 07:10 AM
  2. Battery Calibration Issue
    By Freelance1040 in forum OnePlus One
    Last Post: 03-08-2015, 01:33 AM
  3. Android System and Battery Life
    By psyberjay in forum Samsung Galaxy Note 4
    Last Post: 11-08-2014, 08:37 PM
  4. Why is my battery life decreasing when charging?
    By MishMomo in forum Ask a Question
    Last Post: 11-07-2014, 07:43 PM
  5. Replies: 3
    Last Post: 11-07-2014, 07:32 PM
