Originally Posted by
1901Madison I have all of these off as well and my idle drain is approximately 1% per hour. Not as good as the Maxx, but not bad either. Interestingly, while the Maxx had better idle battery life, the Turbo is actually giving me better screen on battery than the Maxx.
Agree, I'm starting to notice that I'm getting better SOT and overall battery life on this phone than the Maxx. The main reason from what I can tell, is that the discharge rate is so consistent. Once below 50%, it's a true 50% whereas with the Maxx, the 2nd 50% went down significantly faster than the 1st. In terms of balance, that would explain why the idle drain seems worse once you pull the phone off the charger, but in reality, any phone the moment you pull it off the charger is of course discharging. A lot of phones just don't seem to interpret the loss until you put the device to use. I've noticed this with the iPhone too. It will stay at 100% for a long time off the charger, but when you start using it, it will jump down, and seemingly jump down faster if it stuck close to100% while off the charger for many hours. That can only mean that the 100% is really just a false reading, and the battery stats are misinterpreting the battery data at that time. The same thing seemed to occur with my Maxx. I would love waking up after 10 hours off the charger and seeing it at 98% in the morning, convincing me that the idle drain was out of this world. But when I started using the phone, it would drop relatively quickly to the mid 80s,where it would then begin to plateau for a while. This can only mean that the initial reading is not all that accurate. This isn't the case with the Turbo, so I don't have that wow effect when I first wake up, but as I use it throughout the day, I'm beginning to marvel at its consistency, and especially how much resiliency it has after it dips below 50,40,30 and so on.
