1. Davidoo's Avatar
    In Settings/Apps/All there is a Sound Recorder App listed. However, in my Apps list from the link on my home page there is no icon for Sound Recorder. How do you open Sound Recorder when there is no icon?
    11-09-2014 10:28 PM
  2. maxman1's Avatar
    I think this is for recording your voice for Moto Voice & Google Now.
    11-09-2014 10:31 PM
  3. Bamzilla's Avatar
    That was listed in my Galaxy Nexus as well but there was no built in app for it. I use Easy Voice Recorder Pro. There's a free version too. Has a blue microphone icon.
    Sent from my XT1254 using Tapatalk
    11-10-2014 05:34 AM
  4. Davidoo's Avatar
    Good suggestion, thanks. Still seems odd that the device has a sound recorder that you are not allowed to open.
    11-10-2014 11:20 AM
  5. maxman1's Avatar
    All the voice commands are actually recorded, sent to servers online for response & actions.
    11-10-2014 05:44 PM
  6. dungoyle's Avatar
    The point being that the Sound Recorder you're seeing isn't for you to use for note taking, it's for the above purpose outlined by maxman1. A built in note taking application might have been nice, but as others have mentioned, the Play Store has some free ones.
    11-10-2014 05:52 PM
  7. Davidoo's Avatar
    I understand there are apps in the Play Store that will do this, but I avoid adding these to my device whenever possible. If you look at most of those apps they ask for a lot of permissions just so you can record something. Not sure why all the Samsung devices I had always had an icon to open the "Voice Recorder" or "Sound Recorder." OK, I've beat this dead horse and will quit now.
    11-10-2014 09:11 PM
  8. VWFeature's Avatar
    Look in apps under "Voice Recorder" with an icon of an old reel to reel tape recorder.
    01-29-2015 02:00 PM
  9. Davidoo's Avatar
    You must not have a Turbo because the Turbo doesn't have this in the apps.
    01-29-2015 04:09 PM
  10. this_is_nascar's Avatar
    I think he means the Apps section of the Play Store.
    Sent with my Kindle Fire HDX 7" via Tapatalk.
    01-29-2015 06:09 PM
  11. Bamzilla's Avatar
    Other options to use is Google Keep or simply in Google say "note to self"
    01-30-2015 07:32 PM
  12. Jeanine Baunsgard's Avatar
    I'm interested in this question too. I have the droid turbo, and would like to record my voice for an alarm. Can't find anywhere how to do this, any suggestions?
    04-17-2015 01:29 AM
  13. SocialMe2016's Avatar
    It WAS showing up of my GS6 until the last update. I can still access it through the Voice Command. Go to Smart Voice then say> Voice Recorder.
    11-15-2015 12:29 PM
  14. 4jsp's Avatar
    The only way I found to open the voice recorder on the HTC 10 is to use Okay Google and say start voice recorder.
    03-02-2017 12:10 AM
  1. What does itunes do?
    By acsurfer in forum The Android Central Lounge
    Last Post: 11-17-2014, 02:36 AM
  2. How to fix this screen distortion on Android x86?
    By SteelBeowulf in forum Android 4.4 KitKat
    Last Post: 11-10-2014, 12:44 PM
  3. Replies: 2
    Last Post: 11-10-2014, 11:22 AM
  4. How do I track my phone that got stolen?
    By Daniel Yates in forum General Help and How To
    Last Post: 11-09-2014, 09:23 PM
