1. johnnyshinta's Avatar
    Is there a difference in dementions between the 2 materials? Some of the reviews that I am reading are saying the ballistic nylon version is thicker and heavier. True?
    11-11-2014 06:30 AM
  2. javiram's Avatar
    Just by briefly looking at and touching them, I did not notice any obvious differences as to size and weight, but I think the Nylon (which I bought) looks cooler and feels nicer.
    11-11-2014 07:19 AM
  3. javiram's Avatar
    There is a slight difference. This is from the Motorola website:
    Dimensions
    Black Ballistic Nylon
    Height: 143.5 mm (5.65 inches)
    Width: 73.3 mm (2.89 inches)
    Curve: 8.3-11.2 mm (0.33-0.44 inches)
    Metallic Red, Metallic Black
    Curve: 7.8-10.6 mm (0.31-0.42 inches)
    Weight
    176 grams (6.2 ounces)
    169 grams (6.0 ounces)
    11-11-2014 07:25 AM
  1. Anyone find a good glass screen protector.
    By lindseybp in forum Sony Xperia Z3 Compact
    Last Post: 11-11-2014, 02:37 PM
  2. Z3V vs One M8
    By Justin Stepp in forum Sony Xperia Z3v
    Last Post: 11-10-2014, 08:37 PM
  3. M8 vs Z3V
    By Justin Stepp in forum Phone Wars
    Last Post: 11-10-2014, 04:39 PM
  4. Plastic or tempered glass screen protectors
    By clickerman in forum Samsung Galaxy Note 4
    Last Post: 11-10-2014, 03:41 PM
  5. Global vs US radios
    By Xedrek in forum General Carrier Discussion
    Last Post: 11-10-2014, 03:36 PM
