1. johnnyshinta's Avatar
    My turbo charger is making my phone pretty warm. It happens when I charger it from several % levels. Not just when the battery is low. Is it normal? Will it hurt the battery?
    11-11-2014 10:46 AM
  2. rxgadget's Avatar
    I am getting high tempos just using the phone
    Sent using my Verizon Turbo charged 64GB Ballistic Nylon phone unfortunately with a case on back
    11-11-2014 01:42 PM
  3. camachinist's Avatar
    I've noted the temp increase more when charging from a low battery level, which makes sense since the charger hits the phone with more voltage for rapid charging at those levels. More activity = more heat.
    Also, I've noted the phone doesn't get as warm now, about 2 weeks in, when charging from low battery levels versus when it was received (online order) with zero charge.
    11-12-2014 12:40 PM
  4. spunkmeijer's Avatar
    Yeah, I have been getting this also when I am put my phone on the charger under 20%, but it cools off past that. This does not happen with another charger, so I took it as normal functionality of the rapid charging system.
    11-12-2014 12:44 PM
  1. Does the Droid Turbo Support the Chromecast cast screen function?
    By nickfili in forum Motorola Droid Turbo
    Last Post: 12-18-2014, 09:43 AM
  2. straight talk says 3g, my phone says lte?
    By sHaWnAlYnNgAmMeL in forum Samsung Galaxy S3
    Last Post: 11-16-2014, 08:33 AM
  3. Click on a phone number in a website and open up the dialer?
    By landolakesgirl in forum Ask a Question
    Last Post: 11-12-2014, 11:59 AM
  4. Leaving plugged my phone al night affect battery life?
    By WP_290 in forum Ask a Question
    Last Post: 11-11-2014, 12:42 PM
  5. Droid Turbo Review: GSMArena
    By PowrDroid in forum Motorola Droid Turbo
    Last Post: 11-11-2014, 09:07 AM
