Received my iOttie Flex III today. Initial reaction is...meh.
The suction to my curved, slightly patterned dash is stellar (don't think it is going anywhere anytime soon). However, a few things about it's actual function:
- Holds the phone, but I wouldn't call it a snug fit. Because of the phone's rounded back and the vice-close button sticking out the back of the mount (more on that in a second), the phone is very wobbly in the doc. Do I think the phone will slip out of it? No. However, it is annoying when going to touch the screen and the phone is rocking back and forth with each press.
- It's awkward releasing the phone from the device. Earlier models of the iOttie appear to have compression wings to release the grip (press each wing inward, phone is released into your waiting palm). However, with the Flex III model, you need to manually open the vice arm. And if you don't hold the phone with your other hand, it will fall to the floor.
- Finally, the 'one-handed mount' mechanism comes down to a button in the middle of the back of the dock. Lock open the vice, push phone in with a bit of force, vice arm closes in to secure phone once button is compressed. This is all well-and-good, but since our phone is a bit large, the button doesn't fully depress when the phone is in the craddle (when the arms are completely closed or close to it, the button is flush with the back of the mount). Thus, you have a spring loaded button putting pressure on one spot on the back of the phone (which also leads to bullet point 1 issues). If you have the 32gb/Kevlar model, that might not be a concern. But I have the Ballistic Nylon model, and I can see the pressure of the button eventually leaving a permanent indentation in the BN backing.
I'll keep it and use it for a few days or so, and report back. But, initially, it appears that the search continues.
