07-21-2017 11:19 AM
46 12
tools
  1. mrtonk's Avatar
    This never happens to mine. Isnt ART the default after Lollipop?
    Sent from my XT1254 using Tapatalk
    maxman1 likes this.
    07-23-2015 10:32 PM
  2. tvouge's Avatar
    Yes, ART is now default.
    For the people experiencing this, the first time you reboot after a cache wipe you SHOULD see this message, because Android is (in my own words) organizing and optimizing the system with the apps you have installed (someone will probably correct me with the proper vernacular).
    After the initial optimization post cache wipe, reboot the phone again. If this continues to happen and it bothers you, a factory reset ought to fix the problem.
    07-23-2015 10:37 PM
  3. celts005's Avatar
    i did factory reset / wipe cache.. but im stuck again.."android is upgrading..optimizing 1..."
    i dont know how to use .. adb sideload?
    07-24-2015 07:36 PM
  4. Davidoo's Avatar
    I have never had my apps optimize after just a cache wipe and I do it once a week. The only time my apps have ever gone through the optimizing is when there is an OTA update such as the two we have had recently.
    07-24-2015 09:40 PM
  5. Bianca Thompson's Avatar
    I have the same issue with my z3 compact but it's that bad that if wont tern on at all anymore it use too load the the optermizing app # of# now it's just black won't vibrate won't do nothing won't load to the computer no red light nothing it's just a $500 paper weight now ! And only 1 year old !! Please help I don't even know who to call to get help
    08-31-2015 04:42 AM
  6. MattRevs's Avatar
    Just update to Android 5.1
    08-31-2015 01:33 PM
  7. houseofpayne04's Avatar
    My 2013 Moto X with the new Lollipop update from Verizon is also doing this, but not every time. I can't seem to identify why it does it sometimes and not others. It has done it on both manual restarts and on a spontaneous restart (for which this phone is infamous).
    09-22-2015 01:40 PM
  8. JemfunkOne's Avatar
    Hi, i've switched to Run ART. How long does it take my tablet to reboot once i've pressed OK? (as it's taking ages to come back on). Thank you
    10-09-2015 07:30 AM
  9. nelly kumar Gurung's Avatar
    Wipi data rset
    10-11-2015 08:18 AM
  10. Jackie Lesko's Avatar
    Every time I power the phone off and back on it thinks it's upgrading Android and takes a long time because it goes through Optimizing the apps. Anyone have a fix for this?
    Thanks
    T MOBILE fixed my optimizing problem. Just talk to the tech dept
    10-25-2015 09:16 PM
  11. bigbadwulff's Avatar
    My MotoX did the same thing after the 5.1 update. Don't know of a fix for it. That and another problem pushed me to a Turbo. It had 5.1 when I got it.
    10-26-2015 09:46 PM
  12. Dan Lo-Fat's Avatar
    Too bad no switching option once in Lollipop, though, still happens now on the Turbo 2! BUT, at least it is quick (5 minutes tops, still beats the old Droid 4 10 minutes normal boot times!)
    11-30-2015 01:40 AM
  13. Dan Lo-Fat's Avatar
    Dont believe you, because you didnt post the fix.
    11-30-2015 01:41 AM
  14. Dan Lo-Fat's Avatar
    ART is the issue, switch back to Dalvik
    11-30-2015 01:42 AM
  15. mrtonk's Avatar
    How?
    11-30-2015 07:20 AM
  16. BiRONIC's Avatar
    this is happening to me now
    not always consistent number of apps being 'optimized'
    sometimes it's 200+ and sometimes it's like 46
    what's up with that?
    i'm doing a cache wipe now to see if it helps.
    01-30-2016 09:00 PM
  17. LONESOMEJAKE's Avatar
    You didn't happen to switch to the ART runtime? If so, that optimizing of apps on restart is a known issue.
    can someone help me I just switched to ART and my phone just booted finally and then ,a popup of an error saying systemui has stopped over and over again nonstop
    I would appreciate it if someone will help me.
    03-12-2016 02:48 AM
  18. Imam khan's Avatar
    Hello, I'm using LG L70. Yesterday I just switched to ART run time mistakenly. From there my phone says
    " android is upgrading " sometimes it is optimizing 56 apps, sometimes 66, and sometimes 148. From last four hours it is showing as starting apps. How can I fix this
    04-12-2016 03:18 AM
  19. bigbadwulff's Avatar
    My RazrM did it which prompted me to get a Turbo. Only happened after software upgrade.
    Please don't do it to my Turbo on next upgrade!!!
    04-18-2016 02:30 PM
  20. Afsar Ali2's Avatar
    Dear All.
    I've booted my Samsung galaxy ace 4 and it gives a notification of SE time and again(SE for Android has been turned off restart your phone to reset your security settings)
    can someone fix it. Also I want to get back my phone from developers mode.
    06-05-2016 06:05 AM
  21. gemszki's Avatar
    07-21-2017 11:19 AM
46 12
  1. Android Wear and Lollipop (Android 5.0)???
    By jean15paul in forum Android Wear / Wear OS
    Last Post: 11-18-2014, 08:04 PM
  2. Ear Speaker crackling issue with DROID phones?
    By leehardballer12 in forum Motorola Droid Turbo
    Last Post: 11-12-2014, 01:53 PM
  3. Yahoo mail & Gmail 5.0 issue on Note 4
    By Nitro211K in forum Samsung Galaxy Note 4
    Last Post: 11-12-2014, 09:14 AM
  4. New to Android: First Steps?
    By Symthic in forum Motorola Droid Turbo
    Last Post: 11-11-2014, 07:00 PM
  5. Will updates to this phone come from Sony?
    By lindseybp in forum Sony Xperia Z3 Compact
    Last Post: 11-11-2014, 03:34 PM
