1. Sodot's Avatar
    I want to set a customized ringtone as my text notification but it will not let me. The customized ringtone will show up in my Phone notification sounds but not in my text notification sounds. I know that it possible to access the SD card documents and manually ad your file to the list of text sounds but I can not find a way into SD card docs. Obviously there is no SD external in the turbo but there still has to be a way to access documents, right?
    11-12-2014 01:52 PM
  2. Ry's Avatar
    I think you need to save it to a media\alerts folder instead of media\ringtones.
    11-12-2014 01:56 PM
  3. edison2012's Avatar
    I use GoSms Pro. Each of my important contacts has a unique notification ringtone (Zedge). Makes it easy to know if I need to look at my phone or not. When I download a notification tone it ends up in my music folder.
    edison
    Sent from my XT1254 using Tapatalk
    11-12-2014 07:53 PM
  4. doogald's Avatar
    Any sound file that you want to be a notification tone should be stored in a folder called "notifications". It can be anywhere in storage - /notifications, /media/notifications, /media/audio/notifications, /foo/bar/notifications, etc. Phone call ringtones are the same except the folder is called "ringtones". Alarm sounds are in a folder called "alarms", unsurprisingly.
    11-12-2014 08:39 PM
  5. TurboFast's Avatar
    Another option is to use the Zedge app and you can save and set ringer and notification tones directly from within the app.
    Pinto66 likes this.
    11-13-2014 01:38 PM
  1. Replies: 1
    Last Post: 01-20-2015, 11:10 AM
  2. Why is my Voice To Text so terrible?
    By mcohen1021 in forum General Help and How To
    Last Post: 11-24-2014, 04:21 PM
  3. motorola x en español
    By Luis Pedro Posadas in forum Moto X (2014)
    Last Post: 11-12-2014, 08:03 PM
  4. What are some good Motorola Droid Turbo Car accessories?
    By Sodot in forum Motorola Droid Turbo
    Last Post: 11-12-2014, 01:49 PM
  5. Replies: 3
    Last Post: 11-12-2014, 08:16 AM
