11-23-2016 09:08 AM
51 123
tools
  1. parkschr1's Avatar
    I was wondering if anyone has been able to get their turbo to read texts while driving. I think I have it set up correctly. I do use handcent.
    11-13-2014 05:06 PM
  2. bradenfontaine's Avatar
    I use the stock messaging, works well when it actually recognizes what I'm saying
    11-13-2014 05:10 PM
  3. parkschr1's Avatar
    What do you say to have it read your texts?
    11-13-2014 05:14 PM
  4. bradenfontaine's Avatar
    When driving if I get a text it automatically says you've received a text from whoever and asks you and if you would like it to be read to you
    11-13-2014 05:15 PM
  5. parkschr1's Avatar
    I wonder if it only works on the stock messaging app?
    11-13-2014 05:17 PM
  6. bradenfontaine's Avatar
    Mayhaps?
    11-13-2014 05:17 PM
  7. vzwuser76's Avatar
    I think I recall seeing the same thing in threads from last year's Droid models. I don't recall if it was ever addressed in an update, since I use the stock app.
    11-13-2014 06:25 PM
  8. Flexia's Avatar
    It works with hangouts
    11-13-2014 06:39 PM
  9. hal1's Avatar
    I've tried most of the app, several which will prompt you and also let you respond by voice, though most of those don't work consistently. For just reading them to you, drivesafe.ly works perfect, everytime, but doesn't read the entire message it it's too long - works with Handcent. The paid version lets you respond by voice.
    11-13-2014 06:45 PM
  10. parkschr1's Avatar
    My turbo is tied into my cars Bluetooth. I wonder if that has anything to do with it.
    11-13-2014 07:04 PM
  11. R Dale D's Avatar
    Works with textra
    11-13-2014 07:04 PM
  12. bizzyqu's Avatar
    if you arent listening to bluetooth music, and your phone is paired, you wont hear the texts because they are being outputted via bluetooth and you are listening to radio or something other than phone. You should still see green turn blue and prompt of you want to respond or listen to the message.
    11-13-2014 08:56 PM
  13. doogald's Avatar
    I know the droid maxx is different - it has a separate assist app, rather than having assist be part of the moto app. But there is a setting in the assist app, audio troubleshooting, that allows using something called an alternate audio channel.
    When I listen to Bluetooth audio, if I get a text, it interrupts and asks me if I want to listen.
    Moto has a support article for the turbo that details this. https://motorola-global-portal.custh...9277/kw/Assist
    One important thing: it only announces texts from people in your address book. That article also lists the alternate channel solution.
    11-13-2014 09:33 PM
  14. rader023's Avatar
    The bluetooth troubleshooting menu is missing from the Turbo. The 2014 phones don't have that anymore. You can tell the help for turbo is wrong because it has an assist app as you mention.
    11-14-2014 12:35 AM
  15. anon(1733)'s Avatar
    At first I wasn't sure on moto assist bit I have found it useful since I spend a ton of time in my car. So far it works quit well
    11-14-2014 10:15 AM
  16. mightyfacundo's Avatar
    It works with Handcent. I used it while driving this morning. It alerts me to the text and asks me to say listen if I want it to read it to me.
    11-14-2014 11:38 AM
  17. NexusShark's Avatar
    Most noticeable thing I had to do was have the location set to "high accuracy" to have it work flawlessly... I don't feel much of a battery difference vs battery saver mode
    11-14-2014 12:40 PM
  18. DoubleMochaMan's Avatar
    It works with Handcent. I used while driving this morning. It alerts me to the text and asks me to say listen if I want it to read it to me.
    And does it let you send a return text, by voice, without ever touching the phone???
    11-14-2014 01:47 PM
  19. mightyfacundo's Avatar
    Yes. I exchanged a bunch of texts this morning while driving. Worked great.
    11-14-2014 02:20 PM
  20. asylvia's Avatar
    under bluetooth click on your call, and click on the option to turn off "media". i had the same issue of no voice when connected and this worked for me. if you want to listen to music just turn media back on.
    11-14-2014 02:20 PM
  21. DoubleMochaMan's Avatar
    I love Moto Assist... have had it for over a year. Others will disagree but I submit that it's safer to use Moto Assist in the car while texting than it is talking to someone next to you in the front seat. In the one case you are looking at and gesturing toward the passenger while talking. In the other case both hands are on the steering wheel and you are looking straight ahead all the time.
    11-14-2014 03:27 PM
  22. mightyfacundo's Avatar
    I agree. This is the first time I've used it, and I thought it was a very cool feature that I look forward to using in the future.
    11-14-2014 04:03 PM
  23. parkschr1's Avatar
    I don't get how everyones is working. It does not work for me. Everything is set up correctly. The only thing I can think of is its not working with my bluetooth in by 2013 Highlander.
    11-14-2014 04:24 PM
  24. parkschr1's Avatar
    Does it work through your bluetooth speakers in your vehicle? I have even turned off the bluetooth and tried getting it to read it out loud from just the phone and it will only pop up on the phone. I do have the box checked for reading text while driving. I have restarted the phone. The phone is unlocked.
    11-14-2014 04:27 PM
  25. mightyfacundo's Avatar
    I'm not sure, but I wasn't using Bluetooth if that helps. (I know it probably doesn't though. Sorry.)
    11-14-2014 04:28 PM
51 123
  1. Best Text Message App For Galaxy S5
    By Woody Wood 0 in forum Ask a Question
    Last Post: 12-17-2015, 08:59 AM
  2. Droid Turbo Rebooting When Connected to Apple airport Wifi ?
    By gdflynn1 in forum Motorola Droid Turbo
    Last Post: 10-25-2015, 10:12 AM
  3. Replies: 1
    Last Post: 11-17-2014, 01:41 AM
  4. What keyboard do you use on your LG G3 mobile phone?
    By Faye27 in forum Ask a Question
    Last Post: 11-13-2014, 01:42 PM
  5. Replies: 0
    Last Post: 11-13-2014, 11:24 AM
