06-30-2015 01:52 PM
2,029 ... 1112131415 ...
tools
  1. doogald's Avatar
    Wow. "Trust" and "Verizon" used in the same sentence. Makes me wonder if you are a Verizon customer?
    Since long before they were Verizon, actually. (1994 or 1995 with Bell Atlantic Mobile, or maybe it was NYNEX Mobile??)
    But I give you this article from last fall for your laughs and enjoyment, from verizon.com:
    Motorola commits to ‘fast’ Lollipop updates for all 2013 and 2014 phones - MyVerizon.com
    02-19-2015 02:23 PM
  2. vzwuser76's Avatar
    Posted via the Turbo
    I'm a Verizon customer, and don't usually trust anything they've got to say. However, if Verizon says the update is incoming it probably is, because they won't say d!ck about anything until it's set in stone and just around the corner.
    02-19-2015 02:25 PM
  3. leprechaun007's Avatar
    System update downloading... Hhnnngggg. Soak test engage?
    02-21-2015 04:34 PM
  4. mcgowane79's Avatar
    Well.............?
    02-21-2015 05:03 PM
  5. leprechaun007's Avatar
    False alarm. Far too quick and I notice no change. Maybe it's a fix for those experiencing the "unable to receive calls" prob. I never had that issue, so I can't say. Version is 21.44.12.en.US
    02-21-2015 05:09 PM
  6. leprechaun007's Avatar
    Negative. Must be some minor bug fix
    02-21-2015 05:15 PM
  7. mcgowane79's Avatar
    leprechaun007 likes this.
    02-21-2015 05:20 PM
  8. Moo Cow's Avatar
    Maybe the first second of audio when you make/receive a phone call with Advanced Calling doesn't cut out with the update, perhaps?
    But I knew this wasn't lollipop. They just reported on the front page of AC as top story right this moment the AT&T Moto phone is getting Lollipop soak test invites. Bet your bottom dollar the Turbo will get the same treatment if it were Lollipop soaks being sent out.
    02-21-2015 11:28 PM
  9. JeffMerr's Avatar
    Will the new update be able to address the low speaker volume issues? This is the only phone I've owned where with the sound all the way up I sometimes miss hearing the sound from text messages and other notifications. Also when I listen to podcasts with headphones, the volume does not go very high. I've turned the EQ off as another thread suggested but didn't notice much of a difference.
    02-22-2015 11:46 PM
  10. dcallan's Avatar
    Phone requires HD (VOLTE) calling on to have decent volume. I should know. I went through 5 Turbos due to call volume issues. There were some issues more recent problems with VOLTE for some users. Some users reported a 2 second delay at the start of every call. I expect a fix in the works for those issues.
    02-23-2015 09:56 AM
  11. jrmt077's Avatar
    Hey Jeff, Myself and many others had the same issue with low volume sound. It has gone around many threads to go into settings, sound, and turn off "audio effects". It worked like a charm for me, now call volume and notification sounds can be adjusted noticeably loud. Try it.
    Edit: I forgot, I had read in some threads that the early builds had the audio effects turned on by default, and later ones it was off by default, don't know if its true, could be they realized the issue.
    02-23-2015 01:00 PM
  12. ckelly33's Avatar
    Do you think I would have to have the VoLTE service turned on to receive the update? I have it off now because it sucks so bad, BUT I'd love for it to work as expected
    02-23-2015 01:15 PM
  13. JJ Jones's Avatar
    I have it turned off and just received the update 10 minutes ago.
    Change log link goes to generic update page. Would be nice to know exactly what this update contains.
    Sent from my Ballistic Turbo
    Attached Thumbnails Droid Turbo: Lollipop software update?-screenshot_2015-02-23-13-14-31.jpg
    02-23-2015 01:17 PM
  14. plumber75's Avatar
    JJ Jones were you part of the soak?
    02-23-2015 01:23 PM
  15. mrcraft2u's Avatar
    I just received the update a few minutes ago and I am not part of the soak test.
    02-23-2015 01:25 PM
  16. JJ Jones's Avatar
    Nope. Never signed up or anything.
    It's odd tho that when you multi tap on the Android Version in the about phone section, it now brings up an S instead of the K. Perhaps it is some type of soak test that's going out via ota to everyone in phases?
    02-23-2015 01:26 PM
  17. mobrules's Avatar
    Just popped up for me
    02-23-2015 01:47 PM
  18. Toes Up's Avatar
    I just received the update as well and I am not part of any soak test.
    02-23-2015 02:29 PM
  19. JJ Jones's Avatar
    I noticed that advanced calling was automatically turned back on after the update.
    Also, and this could be a fluke, signal has improved from (-110 to -108) to (-105 to -102) while sitting on my couch.
    02-23-2015 02:45 PM
  20. ckelly33's Avatar
    So....has VoLTE improved with the update?
    02-23-2015 02:52 PM
  21. slidesJ's Avatar
    Droid Turbo: Lollipop software update?-turbo.png
    Toes Up and dungoyle like this.
    02-23-2015 02:56 PM
  22. Davidoo's Avatar
    I got the update earlier today and my wife and I made several calls to and from each other on her cell and our landline using my turbo and no more delay at all. Interesting though that the notes from Verizon on what was updated didn't mention anything regarding advanced calling delays.
    02-23-2015 03:11 PM
  23. doogald's Avatar
    There is nothing odd about it. The first character of the Build Number is what pops up when you do that on KitKat. On the Droids, they always use an "S", so that's what pops up.
    02-23-2015 03:40 PM
  24. teeitupmo#WN's Avatar
    Just received the 21.44.12 sys update to my Turbo. The Lollipop update is probably a ways away.
    Sent from my iPhone using Tapatalk
    02-23-2015 04:15 PM
  25. ckelly33's Avatar
    Call quality is unchanged. Still really bad. /HD calling off again.
    02-23-2015 05:26 PM
  1. Does your turbo read your texts while driving?
    By parkschr1 in forum Motorola Droid Turbo
    Last Post: 11-23-2016, 10:08 AM
  2. What was this 96meg update from AT&T on my Note 2 today?
    By grimister in forum AT&T Galaxy Note 2
    Last Post: 12-01-2014, 10:05 AM
  3. How do I replicate my KitKat preferences for notifications?
    By germcevoy in forum General Help and How To
    Last Post: 11-15-2014, 02:07 PM
  4. Factory reset before updating to 5.0?
    By acr456 in forum Android 5.0 Lollipop
    Last Post: 11-15-2014, 02:32 AM
  5. can't check for updates!?
    By J00P24 in forum Google Nexus 5
    Last Post: 11-13-2014, 06:38 PM
