06-30-2015 01:52 PM
2,029 ... 6768697071 ...
tools
  1. tdizzel's Avatar
    Finally got lollipop, had to switch to sprint today...bought the s6 edge. Will miss my turbo, but this phone is nice too. Plus it gives me a bunch of new stuff too learn. Best of luck getting the update guys, hope it goes smooth and soon!
    Good luck with the S6. Hope you really enjoy it. Are you gonna have to change your handle to S6Hope now?
    06-14-2015 12:29 AM
  2. GeodudeFFP's Avatar
    I should have chosen my words better, however. I should have said every phone model that has gotten lollipop has had serious issues.
    Still COMPLETELY incorrect. I have no doubt about all the threads regarding problems; nobody's arguing that. But the ridiculous "fact" you re-state immediately above is simply not reality. I myself could easily post 100 threads about having no problems for each of my phones with L.
    In the end, we'll get L regardless, so if you don't want it, plan accordingly. I'll probably reluctantly accept it, and you know what? Everything will be fine...not to my liking, but it will be fine...and then I'll probably hope for M (good luck to me on that!).
    06-14-2015 12:43 AM
  3. tdizzel's Avatar
    Wait, what? You admit that people are reporting problems, but since there are also people reporting no problems, then there are no problems? How? Why? Where? What??? I don't even know what to do with that.
    And i absolutely did not say I don't want L. I have no clue where you got that. I said I want it when its right. Those are two COMPLETELY different things.
    06-14-2015 12:56 AM
  4. GeodudeFFP's Avatar
    EDIT: Comment removed since it did not directly pertain to the subject matter.
    06-14-2015 01:03 AM
  5. perithimus's Avatar
    I am taking my crap comment off. It was made in bad taste and I apologize. Very unlike me.
    GeodudeFFP likes this.
    06-14-2015 01:17 AM
  6. GeodudeFFP's Avatar
    And people wonder how politics becomes so ridiculous...
    anon(9227267) and Eclipse2K like this.
    06-14-2015 01:38 AM
  7. vzwuser76's Avatar
    You're comical...
    What he is trying to say is that every phone model that has updated to has had issues with Lollipop, not every single phone itself, but some phones of each model have. And while that happens with every version of Android, the percentages are higher in Lollipop. Like I've stated before, the fact that many Nexus devices are having issues updating proves that. There is no reason that my Nexus 7 2013 WiFi should be getting it's updates as late as they are. They used to update a week or two after release, but with Lollipop it's been a month or two every time. They're made to run a completely stock build and my N7 has no carrier to deal with, so there's no excuse for that.
    Whatever you think of any OEMS or carriers, Lollipop has been a headache for all of them to get out. Every time an update goes out for any particular model, there is a later story about the issues caused by the update. I'm not talking about a few posts here and there on forums, if the issue makes it into the tech blogs, then it's more than just a few people experiencing it.
    06-14-2015 02:18 AM
  8. anon(9227267)'s Avatar
    Currently have 4.4.4,can I refuse the update (if it ever comes) since I am happy with what I have?
    06-14-2015 09:43 AM
  9. teeitupmo#WN's Avatar
    For the record, I have a Galaxy S4T running 5.0.2 and Nexus 6 running 5.1.1 and I have no issues with either device.
    I am happy with the upgrade.
    Sent from my Nexus 6 using Tapatalk
    philly, KPMcClave and TurboHope like this.
    06-14-2015 09:51 AM
  10. Davidoo's Avatar
    And needing to do a factory reset in order for it to function correctly is a problem. Especially since there are going to be an enormous amount of people who have no idea what a factory reset is, let alone how to do one. It shouldn't be that way. You should just be able to get the update and be on your way, not needing to reset and then completely have to set up your phone again.
    Here's where we agree. You should not have to do a factory reset and completely have to set up your phone again. Since I use my Turbo for work, a factory reset and getting all the one time passwords for emails and remote access could take days.
    anon(9227267) likes this.
    06-14-2015 10:20 AM
  11. Richardar6's Avatar
    OK, so far I've learned that people into phones are just as passionate about their devices as people into cars are passionate about their vehicles. The praises and complaints are so similar - design, performance, updates, etc. I get it now. Took years, but I get it. When we are passionate about something, we tend to defend it passionately. We want everyone to understand the great things we see. The problem is there is always someone just as passionate about something else and they are doing the same thing you are.
    With this in mind, take a step back for just a minute. If you like Samsung, good for you. If you like the Turbo, good for you. If you like Lolipop over Kit Kat, or vice versa, good for you. For every object you or I like, there will be someone with either the same or opposite opinion. For every problem I have, there will be someone that doesn't have an issue.
    So if I'm looking forward to Lolipop and you think Kit Kat is better because it's more stable, that's fine- but don't bother to tell me why you think I'm wrong, because then we end up going back and forth trying to prove a point that can't be won. Why? Because none of this BS is a contest.
    06-14-2015 10:45 AM
  12. doogald's Avatar
    If it is like every other android os update, you can defer the install for 24 hours, and it will keep notifying you, every day. If you are diligent about deferring you should be able to prevent the update.
    06-14-2015 11:00 AM
  13. anon(9227267)'s Avatar
    Thank you.
    06-14-2015 11:04 AM
  14. KPMcClave's Avatar
    Many discussions turn in to arguments. Or start that way. Your post is a good thing to keep in mind.
    06-14-2015 12:39 PM
  15. Davidoo's Avatar
    Definitely in agreement. With all the whining and complaining I've done about not getting L, the Turbo is still by far the best device I've had. I guess that's why it bothers me because it will be even more awesome running a new OS!
    06-14-2015 12:47 PM
  16. PowrDroid's Avatar
    This thread has been flogged like a rented Mustang GT.
    06-14-2015 01:59 PM
  17. Rob_B's Avatar
    I agree, I've had quite a few phones over the years (mostly Samsung) and have never had one that operates as smoothly as the turbo. All my other devices were rooted, and my UN rooted turbo booked them out of the water. With the recent awesome camera update, this phone is perfect. I get great shots of my kids, fast performance.
    What camera update? Unless I'm wrong 21.44.12 change log shows nothing about camera fixes for the turbo and that's the last SW update pushed.
    Sent from my XT1254 using Tapatalk
    06-14-2015 05:31 PM
  18. Rob_B's Avatar
    06-14-2015 05:33 PM
  19. berserker's Avatar
    The Motorola Camera app in the Play Store was updated on May 20th.
    06-14-2015 05:38 PM
  20. Rob_B's Avatar
    That update wasn't specifically for the turbo. I'm looking for 5.1 to address problems I, and others, are still experiencing on 4.4.4. If fixing AC 1.0 handoffs and WiFi deficiency were as simple as a play store download don't you think Motorola and Verizon would have pointed us in that direction?
    06-14-2015 06:08 PM
  21. Davidoo's Avatar
    The camera update was through the Google Play store a few weeks ago. It was tested by some and found the shutter lag was reduced significantly by the update.
    06-14-2015 06:51 PM
  22. tvouge's Avatar
    The last moto camera update wasn't specifically for the Turbo, but it significantly decreased the shutter speed on the Turbo.
    As for the other issues you're having, they are baked into the ROM. If they made those services modular, sure they could update them independently through the play store, but they're not.
    06-14-2015 06:53 PM
  23. teeitupmo#WN's Avatar
    I received a camera update just the other day:
    Droid Turbo: Lollipop software update?-uploadfromtaptalk1434322827791.jpg
    06-14-2015 07:00 PM
  24. doogald's Avatar
    That's the Google camera app, which did have an update the other day, but didn't come pre-installed on the phone. The Moto camera app is different, came pre-installed on the phone, and, as already mentioned, was updated a few weeks ago. It didn't just add faster shutter - it also has some manual exposure controls that didn't exist before.
    06-14-2015 08:39 PM
  25. teeitupmo#WN's Avatar
    Sorry guys, my freakn app indicated it failed with the post, I I thought it didn't work. After 3-4 times I gave up. I guess it worked, despite the error in posting.
    06-14-2015 08:52 PM
  1. Does your turbo read your texts while driving?
    By parkschr1 in forum Motorola Droid Turbo
    Last Post: 11-23-2016, 10:08 AM
  2. What was this 96meg update from AT&T on my Note 2 today?
    By grimister in forum AT&T Galaxy Note 2
    Last Post: 12-01-2014, 10:05 AM
  3. How do I replicate my KitKat preferences for notifications?
    By germcevoy in forum General Help and How To
    Last Post: 11-15-2014, 02:07 PM
  4. Factory reset before updating to 5.0?
    By acr456 in forum Android 5.0 Lollipop
    Last Post: 11-15-2014, 02:32 AM
  5. can't check for updates!?
    By J00P24 in forum Google Nexus 5
    Last Post: 11-13-2014, 06:38 PM
