Okay, I have the S5 and Turbo. For those that have made the switch from the S5 to the Turbo, how do you find the signal reception to be? I can get two bars on the Turbo of 4G LTE while the S5 will be full across. I have switched from Global to the LTE/CDMA but that didn't make a difference.
I'm wondering if I have a dud. I can make calls and hear okay but wanted to see if this is the "norm".
TIA for input.
TIA for input.
