1. Toes Up's Avatar
    I notice that quite often I get a "Searching Location" notification. I am concerned that this will impact the battery. Location Reporting and Location History are off. I realize that I can turn "Location" off but I'm guessing that needs to be on for Google Maps and Assist to work. Any thoughts?
    11-18-2014 12:42 PM
  2. B. Diddy's Avatar
    Is your GPS on, or is the Location function on Battery Saving mode?
    I don't think Google Maps is associated with a "Searching Location" notification, so I wonder if you have any other apps installed that have some location-based function. Check the settings of your various apps, and see if there is an app whose location function you can turn off (if you don't need it).
    11-18-2014 01:05 PM
  3. Toes Up's Avatar
    I believe the GPS is "on." I will check my apps to see if that shows anything that can be modified.
    Thanks.
    11-18-2014 01:41 PM
  4. anon(5484072)'s Avatar
    That happened with me because of the moto assist driving and home being on.
    Those two check every minute to see where you are. Once I turned those off, I stopped getting the notification.
    quantum tao, B. Diddy and Toes Up like this.
    11-18-2014 04:23 PM
  1. Location Icon flashing on top left
    By asylvia in forum Motorola Droid Turbo
    Last Post: 06-30-2015, 02:32 AM
  2. Replies: 5
    Last Post: 01-24-2015, 09:34 AM
  3. Why is my tablet freezing after I had search images and save it?
    By Shan Mark Cadigal in forum Ask a Question
    Last Post: 11-17-2014, 03:36 PM
  4. Google Search crashing
    By Philipp Yeo in forum Ask a Question
    Last Post: 11-17-2014, 02:04 PM
