04-03-2015 11:36 AM
52 123
tools
  1. Davidoo's Avatar
    It does the same thing with the Verizon charger. I wish it could charge with the phone off too.
    11-20-2014 07:28 AM
  2. MA2GA28's Avatar
    Does the phone turn on, or is it just the 'charging' battery animation?
    11-20-2014 08:54 AM
  3. Fable's Avatar
    It turns on.
    11-20-2014 09:15 AM
  4. dgross20832's Avatar
    I am currently on my 2nd Qi Charging Stand (VZW3COIL-WC).
    I like the charger itself, especially the angle but according the included instructions once the phone has completed charging the red LED is supposed to turn off however my red light stays on as long as the phone is on the dock. The ONLY time I see the LED off (Standby Mode) is when the phone is not on the dock. Verizon is aware of this issue but they are not sure what the problem is but they are looking into it. Has anybody else had this issue? Know how to fix it? Thanks So Much in Advance.
    01-27-2015 04:05 PM
  5. HappyFunBall24's Avatar
    Hey folks, not meaning to hijack, but a quick word: qi charging doesn't work if you have a case with metal on the back, such as a kickstand, that comes in-between the charging plate and the battery.
    I just found this out in using my Tylt Vu with a case that has a metal kickstand; I discussed this in more detail in the cases thread, but thought I'd give a heads-up here.
    01-28-2015 12:07 PM
  6. cbironman24's Avatar
    Works fine on my Verizon Qi stand with Seidio case on the phone.
    01-28-2015 01:18 PM
  7. Hanko's Avatar
    This charger from Microsoft works very well with the Droid Turbo.
    01-29-2015 12:49 PM
  8. dgross20832's Avatar
    Does the light on the stand turn off when the phone is fully charged?
    01-29-2015 01:09 PM
  9. Bob-B's Avatar
    I have the Verizon one. It works fine. I chose it over the Tylt Vu because the Tylt Vu takes up so much space (I use it on my nightstand) and the Verizon one doesn't. The charging light is quite dim, no problem on a nightstand.
    01-29-2015 02:03 PM
  10. dgross20832's Avatar
    Thanks, I am just trying to figure out why the red light does not go out on the Verizon stand as the directions that came with it said the light should go out when the phone is charged.
    01-29-2015 02:35 PM
  11. cbironman24's Avatar
    The red light on my Verizon stand goes out when the phone is done charging.
    01-29-2015 03:30 PM
  12. dgross20832's Avatar
    Are you using a Note 4. Did you change any settings on the phone itself? Thanks Much
    01-29-2015 03:33 PM
  13. cbironman24's Avatar
    I'm using a droid turbo. Didn't touch any settings on the phone.
    01-29-2015 03:35 PM
  14. Davidoo's Avatar
    I have the Verizon stand and the light goes out after it is finished charging.
    01-29-2015 04:05 PM
  15. this_is_nascar's Avatar
    Thinking about getting the Verizon branded wireless charger for my Turbo. Any negatives over using the corded Turbo turbo charger?
    Sent with my Kindle Fire HDX 7" via Tapatalk.
    01-29-2015 06:06 PM
  16. Davidoo's Avatar
    The only negative I can think of, and I think all Qi chargers work this way, is that you can't use it with the phone off. I turn my phone off each night and charge it. You can do this with the plug in charger, but as soon as you put it on Qi charger the phone comes on.
    01-29-2015 07:11 PM
  17. Bob-B's Avatar
    I forgot to mention above that with the Verizon charger, it usually only charges to 99% even with an overnight charge, so the red light doesn't go out. Every now and then it will go to 100%, but usually not. The 99% doesn't bother me a bit.
    01-29-2015 07:32 PM
  18. carldc's Avatar
    Here's another one to throw into the mix:
    Tmvel T3 Qi Wireless 3-Coils Folding Charging Stand for Qi-Enabled ... http://www.amazon.com/dp/B00P6OMD96/...cUvbUpU4205207
    I use it with my Galaxy Alpha and it charges just fine even through a Krusell case.
    01-29-2015 07:35 PM
  19. D._Manley's Avatar
    Tmvel T3 Qi Wireless 3-Coils Folding Charging Stand for Qi-Enabled ... http://www.amazon.com/dp/B00P6OMD96/...cUvbUpU4205413
    Gave this one for Christmas gift - works great. Had I not gotten the Tylt special deal I would have got this one for myself as well.
    01-29-2015 10:32 PM
  20. gadgetgeek703's Avatar
    I have noticed this myself. The only difference is my red light does go out. I had just attributed the 99% to a small amount of battery used between the time the charger cut off and the time I took it off the charger.
    01-30-2015 09:45 AM
  21. PowrDroid's Avatar
    I've held off on getting a Qi charger because of numerous reports they play havoc with the battery meter. Search this forum for more info.
    01-30-2015 10:04 AM
  22. Jay Evans's Avatar
    I had one problem right after I got the phone in Dec. Never again since then. My wife liked my VZW charger so much she bought one for her phone and has never had a problem with her Turbo on it.
    01-30-2015 11:12 AM
  23. PowrDroid's Avatar
    How long is the power cord on the VZW Qi charger?
    01-30-2015 11:47 AM
  24. this_is_nascar's Avatar
    Thanks for all the great feedback everyone.
    Sent from my Droid Turbo 64-gig from Tapatalk.
    01-30-2015 01:50 PM
  25. dungoyle's Avatar
    Tmvel T3 Qi Wireless 3-Coils Folding Charging Stand for Qi-Enabled ... Amazon.com: Tmvel T3 Qi Wireless 3-Coils Folding Charging Stand for Qi-Enabled Phones and Tablets Note 4 , S5, Nexus 6, Nexus 5 - Retail Packaging: Cell Phones & Accessories
    I love the look and apparent functionality of this charger. I do think it's priced on the high side, and that plus I bought two of the TYLTs when they were half priced keeps me away. Very very nice looking product though.
    01-31-2015 09:18 AM
52 123
  1. Nexus 10 with Lollipop Performance? vs. Nexus 7 2013?
    By Deferno54 in forum Google Nexus 10 Tablet
    Last Post: 11-20-2014, 10:00 AM
  2. Why do chargers stop working when connecting to the phone?
    By JKHTCOneX in forum Ask a Question
    Last Post: 11-19-2014, 02:02 PM
  3. Replies: 0
    Last Post: 11-19-2014, 08:12 AM
  4. Turbo charger USB cable tip
    By billbrobaggins in forum Motorola Droid Turbo
    Last Post: 11-19-2014, 07:42 AM
