1. gmermel's Avatar
    https://play.google.com/store/apps/d...vito.lux&hl=en
    This app allows you to set your screen brightness for different levels of ambient light. You go in to the app, and it tells you what it's reading as ambient. Then, you set the slider for the brightness that works for you. Once you do this for several different light levels, it will then set the screen proportionately to the ambient levels between the ones you have set.
    My N7 screen was too dim in soft light, which led me to this app. Has worked well for me since.....
    Good luck
    11-19-2014 05:24 PM
  2. gmermel's Avatar
    OOOPppps. Meant this for the Nexus 6 forum. I had this forum opened, and the N6 on another page. Dummy went and chose "new thread" on the wrong one.. Sorry, and cheers. I'll probably be getting the turbo after my 6 arrives and I confirm the battery life won't meet my needs, so it's not like I'm intruding for no reason.......
    11-19-2014 05:32 PM
  1. Mark on the screen from scrolling?
    By punk999 in forum Samsung Galaxy S5
    Last Post: 11-19-2014, 09:42 PM
  2. Screen comes on with Msg's? Stopping notification?
    By ffactoryxx in forum Motorola Droid Turbo
    Last Post: 11-19-2014, 07:20 PM
  3. Screen always on: potential damage?
    By Eddy Tam1 in forum Samsung Galaxy Note 3
    Last Post: 11-19-2014, 04:53 PM
  4. Replies: 2
    Last Post: 11-19-2014, 04:23 PM
  5. Need Help. Stuck at boot screen
    By psychoD33x in forum Motorola Droid MAXX
    Last Post: 11-19-2014, 02:07 PM
