1. fonger13's Avatar
    I have my wifi set to off when phone is asleep unless it's charging, yet when I go to view the battery graph it show wifi as always on.
    I'm I not understanding the graph? I did a test the other day when I manually turn wifi off, sure enough over 8 hrs I noticed wifi using less battery and it was shown as off on the battery graph.
    Has anyone else notice this?
    11-24-2014 02:05 PM
  2. Xelios's Avatar
    Yeah. Go to your wifi, and hit the menu button, and go to Advanced Settings. There's an option in there checked that says Always Scanning or something like that. You'll want to turn that one off, that will fully disable it.
    mobrules likes this.
    11-24-2014 10:56 PM
  3. fonger13's Avatar
    I have Always Scanning off. I don't think the setting for 'Off when phone sleep' actually work. Probably why the turbo has a higher stand by drain than other phones.
    11-25-2014 08:11 AM
  4. Javier P's Avatar
    If you have an antivirus or similar app check in the anti - theft settings. Other people reported that as the culprit for a similar problem.
    11-25-2014 08:22 AM
  5. kmf1's Avatar
    What is accomplished by having Always Scanning turned off? I suppose that it consumes more battery Always Scanning?
    11-25-2014 09:32 AM
  1. Why is my Moto X having new wifi issues?
    By ILoveMyMotoX in forum Moto X (2013)
    Last Post: 11-26-2014, 11:34 AM
  2. Why does the Play store popup on G3?
    By W1ngcommander in forum LG G3
    Last Post: 11-25-2014, 03:50 PM
  3. How is the wifi on the Android Netbook?
    By JoeMaggs in forum General Help and How To
    Last Post: 11-25-2014, 10:45 AM
  4. Replies: 1
    Last Post: 11-25-2014, 01:08 AM
  5. How fix broken Power button on Samsung Galaxy Mini?
    By Claude Speed in forum Ask a Question
    Last Post: 11-25-2014, 12:58 AM
