1. bfranker's Avatar
    Hello!
    Can you guys tell me if there might be a setting that would cause my phone to use cell towers for data as opposed to WiFi even when I'm connected to WiFi or does the phone always, no matter what, use the WiFi when it's connected? Reason I ask is because it seems like my Turbo is going through data like crazy! I normally use .6 to .7gb per month and I'm already at .7 in 10 days. I recognize that when I first got it I downloaded most my apps via the cell tower data but was under .3 at that time and checked the setting to only auto update when connected to WiFi but even since then I've used like .4 in 5 days which is a lot for me! I also recognize that it also may be because I got a new phone and am using it more but want to make sure I'm not missing something
    Thanks!
    11-25-2014 12:39 AM
  2. bfranker's Avatar
    Oh shoot... I just noticed that in another thread here named "data usage" that what is being talked about there may be my issue as well. I've sub'd to that thread.
    11-25-2014 02:15 AM
  3. jesta192's Avatar
    There is a software update coming down which, for me at least, seems to have solved the problem. Unfortunately, Verizon doesn't mention whether the problem was specifically addressed, but so far it's looking good.
    12-12-2014 11:29 AM
  1. no wifi after kitkat 4.4.2 update
    By Jesse Labadlabad in forum ASUS Fonepad 7
    Last Post: 12-29-2014, 09:26 AM
  2. Value for Money 10" Tablet
    By caslad66 in forum General News & Discussion
    Last Post: 12-14-2014, 09:21 AM
