1. droidXclone's Avatar
    Hi all, I have a question about data network selection on the Turbo:
    Is there a way to force the Turbo into 3G even when in an LTE zone? This is something I occasionally do in high density areas such as sporting events, to improve my data signal when there are a lot of people using the 4G network, or when I'm in marginal 4G coverage... I currently use Advanced Signal Status but a previous update on my GS3 blocked it, until I rooted. I'm not sure if that was Samsung's or Verizon's doing, if it was Verizon I'm guessing they block its usage on the Turbo as well. I know there is not root available yet, and Advanced Signal Status is one of the main reasons I rooted my GS3.
    Thanks!
    11-28-2014 10:30 AM
  2. mobrules's Avatar
    Thanks!
    https://play.google.com/store/apps/d...se.LTEswitcher I use an older version of this app. It works.
    droidXclone likes this.
    11-28-2014 11:24 AM
  1. T-Mobile N6 order status?
    By va2azerik in forum Google Nexus 6
    Last Post: 02-04-2015, 07:59 PM
  2. nexus 6 and advanced task manager
    By kayfaei in forum Google Nexus 6
    Last Post: 12-15-2014, 04:56 PM
  3. Can anyone tell me what the symbol on my status bar is?
    By Ignasis in forum Ask a Question
    Last Post: 11-27-2014, 12:13 PM
  4. Sprint Nexus 6 not getting LTE signals reliable
    By edwarto#CB in forum Google Nexus 6
    Last Post: 11-25-2014, 11:43 AM
  5. Why can't I get a signal on my Note 3?
    By phat0074 in forum Samsung Galaxy Note 3
    Last Post: 11-25-2014, 10:25 AM
