1. tmcmack's Avatar
    Hi, all. On previous phones I had an easy way of switching between normal volume and vibrate from the lock screen. On my droid Razr with cyanogenmod, I could hold a capacitive button from the lock screen to go to vibrate. Is there any way to go to vibrate from the Turbo lock screen? Haven't found an app that will let me add some way to do that.
    (Can't wait for cyanogenmod to be available on the turbo.)
    11-29-2014 06:43 PM
  2. bfranker's Avatar
    If you hold the power button for a second with the phone on the lock screen it comes up and allows you to select vibrate or normal. Or are you talking about something different? I don't have an actual lock code on mine so maybe it's different?
    If you are looking for something else and don't care about the twist twice for camera, I'm pretty sure you can use MacroDroid to twist twice and have it toggle between vibrate and normal and then you don't even have to press any button
    11-29-2014 07:14 PM
  3. Furt's Avatar
    hold power button, toggles are on bottom of power menu.
    11-29-2014 07:17 PM
  4. tmcmack's Avatar
    I'll try MacroDroid, thanks. I'm just looking for the fastest possible way to get to silent, instead of typing in my number lock, holding the power button, and so on.
    Sent from my XT1254 using Tapatalk
    11-30-2014 07:06 AM
  1. Huawei Honor 6 won't turn on?
    By oblivion64 in forum General Help and How To
    Last Post: 01-21-2019, 03:01 PM
  2. Replies: 5
    Last Post: 12-03-2014, 06:47 PM
  3. Think I set the wrong language/region at setup...
    By ODog2323 in forum Google Nexus 6
    Last Post: 11-29-2014, 10:50 PM
  4. Automated On/Off for WiFi Calling
    By kct1975 in forum HTC One M8
    Last Post: 11-29-2014, 09:34 PM
  5. Replies: 1
    Last Post: 11-29-2014, 06:56 PM
