1. Rndcheg's Avatar
    Has anyone tried this and successfully removed apps loaded on the system directory? Just curious as I did not know you can do this without rooting the device. If anyone has, please report in on the results. Thanks.
    I have not posted enough to add the link so here is the description.
    HOW TO REMOVE BLOATWARE (DEFAULT APPS) FROM MOTOROLA DROID TURBO – EASY GUIDE - posted on Android Devices.
    12-01-2014 12:02 AM
  2. tvouge's Avatar
    It doesn't remove them, it simply disables them. It just automates what you can already do.
    Rndcheg likes this.
    12-01-2014 01:08 AM
  3. Rndcheg's Avatar
    well that is lame. There are a couple that I cannot disable but not worth messing with it for a couple - V/M and Stock Messenger. Thanks for responding.
    12-01-2014 10:09 AM
  1. How do I remove Google Now's white band from screen?
    By Snkan in forum Android 5.0 Lollipop
    Last Post: 08-06-2015, 04:12 PM
  2. How to permanently remove Radio Paradise playlist?
    By erpence in forum Ask a Question
    Last Post: 12-04-2014, 11:04 AM
  3. How do I remove empty home screens?
    By whandjr in forum Android 4.4 KitKat
    Last Post: 12-01-2014, 01:54 AM
  4. Any AT&T nexus 6 owner try to remove AT&T logo?
    By eak1570 in forum Google Nexus 6
    Last Post: 11-30-2014, 05:33 AM
  5. How do I automatically remove header details in forwarded mail?
    By Renuka Shahaney in forum Ask a Question
    Last Post: 11-30-2014, 01:23 AM
