1. marlin29311's Avatar
    Is anyone else having issues with the Android system causing a permanent wakelock? It just started happening to me the other day. If I reboot, it will not cause a lock for around 12-14 hours, and then it just randomly starts again. I've cleared my cache partition, but outside of that, any ideas on what's causing this?
    12-01-2014 12:29 PM
  2. B. Diddy's Avatar
    Do you have an alarm set? I've seen issues where setting an alarm actually keeps the system awake the whole time, as if the phone is constantly reminding itself that an alarm is coming up. This would obviously be a glitch, but I'm not sure if there's a solution for it yet (besides not using the alarm clock).
    12-01-2014 04:27 PM
  3. marlin29311's Avatar
    Wish it was the case - I don't even have an alarm saved in the clock at all as it is. Thanks for the idea though - wouldn't have even thought of that.
    12-01-2014 04:40 PM
  4. doogald's Avatar
    It could be an app updating in the background, it could be a widget on a home screen. It could be a lot of things and, unfortunately, Google hasn't made it very easy to diagnose.
    Did you happen to turn on the Google Now "OK Google" detection from any screen? (This is distinct from Moto Voice.) This could be holding the phone constantly awake. (Google app in the app drawer, or open Google Now, scroll to the bottom, tap the menu control on the bottom right, settings, voice, OK Google detection - are those options turned on?)
    Do you have any apps that do automatic switching of tasks, like Tasker, AutomateIt, IFTTT, Llama?
    12-01-2014 05:58 PM
  5. mobrules's Avatar
    Install Gsam battery monitor. It has a feature called app sucker that shows which apps use battery percentages. That screen has a drop down to change it to view kernel wakelocks. Then you can actually select each one for more detail and there is an option to google each wakelock to see what is causing it. hope this helps.
    12-01-2014 07:08 PM
  1. Android Device Manager
    By DX9 in forum Samsung Galaxy Note 4
    Last Post: 03-06-2015, 12:19 AM
  2. Verizon issues
    By reb0957 in forum Samsung Galaxy Note 4
    Last Post: 12-02-2014, 06:02 PM
  3. ANY IDEAS? - smart stay issues
    By bassplayrguy in forum Samsung Galaxy Note 4
    Last Post: 12-01-2014, 07:35 PM
  4. Finger touch issue
    By Leonardo Hansen in forum Samsung Galaxy Note 4
    Last Post: 12-01-2014, 04:13 PM
  5. How can I recover my Android Device Manager lock password?
    By romcarlos13 in forum Ask a Question
    Last Post: 12-01-2014, 12:38 PM
