1. brandonx1000's Avatar
    Never had this problem with a previous phone. I've had it since the day before Thanksgiving. The "b" on my keyboard refused to type. I reset the phone and all is good. I ran a few screen test apps and all is normal.
    Should this be a concern or should I consider this a one off?
    12-02-2014 07:09 PM
  2. KCAndroid1's Avatar
    Since a reset fixed it, it was almost certainly a software congestion kind of problem and not the hardware that makes your touchscreen work. I doubt it's coming back and I wouldn't worry about it.
    brandonx1000 likes this.
    12-02-2014 07:43 PM
  1. Is My Turbo Defective? Battery, Heat, and Stability Issues
    By MayonnaiseOreo in forum Motorola Droid Turbo
    Last Post: 04-06-2015, 10:16 AM
  2. Why is my keyboard showing grey slash marks on each letter after I press it?
    By Kishan_Halai in forum General Help and How To
    Last Post: 12-04-2014, 09:07 PM
  3. new note3 2 issues
    By speedspeed in forum Samsung Galaxy Note 3
    Last Post: 12-03-2014, 02:17 AM
  4. Replies: 1
    Last Post: 12-02-2014, 06:32 PM
  5. Slight screen tint issue
    By kroker in forum Samsung Galaxy Tab Pro 10.1
    Last Post: 12-02-2014, 06:20 PM
