12-21-2014 12:16 PM
78 ... 234
tools
  1. Masheen's Avatar
    A fellow on another forum suggested, and I think rightly, that when light is low, a camera can either extend the shutter time or alter the ISO to expose the image. These are film terms of course but still. Extending the shutter time gives a better quality image but induces blur with movement, using the ISO change avoids that but introduces garbage into the image. I believe on a firmware level the manufacturer has to decide how that curve is setup, at x light use x iso and y shutter speed, and there is some room for variation in there. On a big camera one can adjust it, and with better hardware there is more room as well. I think they choose image quality over ability to have a fast shutter at low light levels, if that makes sense...
    You know alot about cameras wolf. I think Moto should let you tune their camera software as you put their entire team to shame.
    12-12-2014 05:58 PM
  2. wolf_walker's Avatar
    I thank you but I don't think I'd go that far. I'm just an obsessive geek with a shutterbug for a wife.
    12-12-2014 06:07 PM
  3. quantum tao's Avatar
    something i noticed is that the turbo does a poor job of deciding when to use flash.
    12-21-2014 12:16 PM
78 ... 234
  1. Why isn't Twitter compatible with the Note Pro???
    By eobet in forum Samsung Galaxy Note Pro 12.2
    Last Post: 08-01-2017, 11:35 PM
  2. Replies: 37
    Last Post: 10-19-2016, 10:56 PM
  3. Change default new photo name?
    By Rikku Watro in forum Ask a Question
    Last Post: 12-15-2014, 01:24 AM
  4. Why is the installed SD not detected?
    By Tita Weng Bay Meris in forum General Help and How To
    Last Post: 12-15-2014, 12:16 AM
  5. Samsung S4 Camera Auto-exit after a minute
    Last Post: 12-14-2014, 05:19 AM
