1. fonger13's Avatar
    Does any know of any tip/trick to reduce background noise when video recording with the turbo?
    I have a G2 and that one focus the sound recording on the subject in your video where was it seems like the Turbo will take in all the sound in the environment, sometime it seems like the capture background noise is actually louder in the video than what it should be.
    12-04-2014 10:06 AM
  2. VidJunky's Avatar
    Noise cancelation is something that is built into your device. There are a couple of apps that claim to do this or improve your existing equipment, however I haven't seen one with a really good rating, so low review scores. You could try one of those.
    12-04-2014 10:26 AM
  1. App to check what LTE frequency you are on (700,1700/2100,1900)
    By dpham00 in forum General Carrier Discussion
    Last Post: 02-10-2015, 10:00 AM
  2. How to root samsung galaxy fresh duos?
    By joaomb in forum Ask a Question
    Last Post: 12-09-2014, 12:17 PM
  3. How to access Android Files from windows via LAN connection?
    By Vikash Verma in forum Ask a Question
    Last Post: 12-05-2014, 01:05 AM
  4. Why does my phone not want to restart well after a new update?
    By Alberto Sanchez2 in forum Ask a Question
    Last Post: 12-04-2014, 02:35 PM
  5. Replies: 1
    Last Post: 12-04-2014, 10:17 AM
