1. HOTHEAD's Avatar
    Basically, i work in a loud environment, I have loud ringtones, and loud notification sounds.
    If I walk into the office areas, and a notification goes off, (sms) I have to retrieve the phone from my pocket, unlock it, and pull the bar down to shut it off.
    On my Razr Maxx, I could press the power button while still in my pocket and it would silence.
    Is there a way to do this on the Turbo??
    Thank you
    Regards
    HOTHEAD
    12-04-2014 12:31 PM
  2. dungoyle's Avatar
    Press and hold the power button, and you'll get a screen that will let you change to vibrate, silence, or airplane.
    12-04-2014 12:35 PM
  3. deesugar's Avatar
    If you press the power button or the volume buttons the phone will indeed stop making noise for that call or notification. I believe that's what you were asking.
    12-04-2014 12:43 PM
  4. HOTHEAD's Avatar
    It silences ringtones, but not notification tones.
    12-04-2014 03:31 PM
  1. Verizon Galaxy Note 2: Ghost image at notification bar
    By jlost in forum Verizon Galaxy Note 2
    Last Post: 12-05-2014, 01:41 PM
  2. Replies: 10
    Last Post: 12-05-2014, 12:09 PM
  3. Cant remove or disable Google Search Toolbar from home screen
    By itic in forum Legacy Android & Other OS's
    Last Post: 12-04-2014, 02:38 PM
  4. Why won't my HTC One start up or charge?
    By gary1963 in forum Ask a Question
    Last Post: 12-04-2014, 02:14 PM
  5. Replies: 2
    Last Post: 12-04-2014, 01:29 PM
