1. Panzer_GSD's Avatar
    Stupid question here. Since my messages didn't get transferred, now is the time possibly change. I think there was a choice between SMS or something else (forget what that was). Within the SMS, if I stay with that, I have the old messaging like I used with my Razr HD or Hangouts or Message+.
    What are the differences?
    12-04-2014 02:23 PM
  2. nedqadams's Avatar
    Well, You can use SMS Backup and Restore (app) on your old phone, save the file to Google Drive then download onto your new phone.
    SMS by itself can be used by multiple apps. Personally I'm using Google's new Messaging app because it's material design and runs fast. Hangouts is a little slow but aggregates your GChat messages and voicemails if you like. Message+ works great because Verizon essentially turns your SMS into data and therefore you can send / receive SMS via data connection or wifi i.e. I went abroad and set it up and was able to get messages without using mobile data. If you spend a lot of time on airplanes and need to stay in touch via GoGo or whatever, it's a good choice too.
    But if you just want standard SMS then Messaging is fine. It's also very similar to the standard Texting app on android. As these all use the same SMSs, then you can move back and forth between them and have the same messages so give it a go.
    Panzer_GSD likes this.
    12-04-2014 03:10 PM
  3. Mike-Mike's Avatar
    8sms is what i use, it looks like the stock Messaging app, but it works better with Android Wear
    12-05-2014 02:17 AM
  1. What is a good messaging app for Android 4.1.2?
    By Marc Tyler in forum Ask a Question
    Last Post: 12-04-2014, 08:34 PM
  2. Why do I have extra characters in Handcent messaging?
    By tslexky in forum Ask a Question
    Last Post: 12-04-2014, 04:15 PM
  3. "Reject call with message" bar
    By Berzelius in forum Samsung Galaxy S3 Mini
    Last Post: 12-04-2014, 12:38 PM
  4. What messaging app
    By ishore99 in forum Samsung Galaxy Tab S 10.5
    Last Post: 12-04-2014, 11:30 AM
  5. How do I get rid of messaging tabs?
    By mrapert in forum HTC One M8
    Last Post: 12-04-2014, 11:22 AM
