12-30-2017 12:08 AM
30 12
tools
  1. leehardballer12's Avatar
    According to the recent report on Android Central, there is no advantage in keeping WiFi off, right?
    No, but I do occasionally get an annoying screen asking me if I want so connect to so-and-so network that is available. So, I end up turning WiFi off when I'm out at a mall, or some other 'public square'.
    12-10-2014 11:05 PM
  2. doogald's Avatar
    Settings / wifi. Turn off the top option, "show wifi pop-up".
    12-11-2014 07:33 AM
  3. Dude_7's Avatar
    Macrodroid
    So far so good with the below macro on a rooted nexus 4.
    Wi-Fi On
    T: Tower(s) in range
    A: Enable Wi-Fi, Data Off
    C: None
    Wi-Fi Off
    T: Tower(s) out of range
    A: Disable Wi-Fi, Data On
    C: None
    12-16-2014 10:23 AM
  4. YouBlue_dev's Avatar
    YouBlue React can do this for you if you connect to Bluetooth (in your car). It can also turn on Bluetooth when you lose WiFi connection and launch an app.
    The way I use it:
    When driving away from home, WiFi disconnects, so it turns on Bluetooth. It connects to my car, which triggers it to launch Pandora. When Bluetooth disconnects, it turns off Bluetooth. I don't use the WiFi toggle, but it's supported.
    05-09-2017 10:14 AM
  5. J MURR's Avatar
    Very helpful
    12-30-2017 12:08 AM
30 12
  1. How to turn on USB Debugging with BROKEN LCD? |LG G2|
    By I2obb in forum General Help and How To
    Last Post: 03-06-2015, 06:54 PM
  2. Replies: 1
    Last Post: 12-04-2014, 02:38 PM
  3. Is there wifi calling on the Samsung Galaxy S5 Actvie?
    By MattP82 in forum Samsung Galaxy S5 Active
    Last Post: 12-04-2014, 02:04 PM
  4. Replies: 1
    Last Post: 12-04-2014, 10:26 AM
  5. Replies: 2
    Last Post: 12-04-2014, 09:23 AM
