12-12-2014 10:28 AM
30 12
tools
  1. Symthic's Avatar
    So I heard here that the Droid Turbo has a problem where when the Wi-Fi is turned on, it still uses the data unless it's explicitly turned off. I experienced this firsthand when I had a YouTube marathon on it one night with the Wi-Fi on, and suddenly got a message telling me 75% of my data was used.
    My data doesn't reset until the 18th, and it's a shared family plan. We're at 90% now, despite us all using as little as possible (or can be governed).
    I read here that someone called Verizon and told them about the issue, and the rep said that it's a known issue that's being worked on, and that he won't be charged for any data overages in the interim. Hoping to get a similar result, I called, but I was instead told that nothing could be done and that I'd have to just bear with it.
    So now what? Was that person's case a unique one and not shared with others, or is my case the exception to the rule? Should I call again and see if they'll be lenient this time? Or am I just screwed?
    Thanks.
    P.S.: If this belongs in the Verizon forum, my apologies. Just felt like this was the most pertinent place, but I might be mistaken.
    12-05-2014 12:11 AM
  2. tvouge's Avatar
    Thanks.
    Question. Have you checked your data usage as recorded on your Verizon account using the Verizon website?
    Because this could simply be a log error on your phone-- I.e. the data counter on your phone is counting ALL data against your predetermined limit.
    12-05-2014 02:36 AM
  3. VZWsucks's Avatar
    Thanks.
    Don't accept it! , call them back and raise hell, remember they work for you. I seen this same issue on another forum website last night, so it's definitely something in the vzw Kool aid. I haven't experienced this myself... I have unlimited everything.
    Sent from my DROID Turbo64
    jesta192 likes this.
    12-05-2014 06:38 AM
  4. NoahForeman's Avatar
    I agree. Call back and be polite but insistent that you should not be charged for their mistake. If need be escalate, escalate, escalate.
    Posted via the Android Central App on my Droid Turbo.
    Hgouck likes this.
    12-05-2014 06:45 AM
  5. jesta192's Avatar
    ... I was instead told that nothing could be done and that I'd have to just bear with it.
    Symthic, you aren't able to use data that you paid for, because it is being used up for you. If Verizon doesn't make it right with you and many others (myself included) who are having this problem, it is outright fraud! Once you go over your data limit, they will begin charging you for overages; that's a scam if I ever heard of one.
    Imagine if you have limited data, but your WiFi connection is also metered. You are then paying overages to two companies for the same data usage. This is unacceptable! I love Verizon's coverage, but they had better get the picture.
    Everyone keep calling them until they agree to not hold their users accountable for this bug!
    12-05-2014 08:48 AM
  6. Jason Smith28's Avatar
    The data usage my Droid Turbo reports is the same as what VZW has recorded. I am not having the same issues.
    12-05-2014 09:40 AM
  7. Almeuit's Avatar
    I would be a little upset at the answer that I have to bear with it ... I would ask them why they would sell me a phone that does that .. When their own tips to save data are to use wifi. If you have to speak with a manager and speak your concerns on how this isn't your fault and you're going to be charged for an issue that shouldn't be an issue? Always stay polite though .. usually getting rude does nothing.
    Hgouck likes this.
    12-05-2014 09:41 AM
  8. dpham00's Avatar
    Call back, and ask to speak to a supervisor if the csr gives you the same crap. Sometimes the csr is lazy, and the easiest answer is, sorry can't help. And make sure to document everything. If the first call won't resolve it, then call again.
    If you end up getting overages because of it then call and ask to have it removed. If not take down their information and let them know that you would like to try to resolve this matter over the phone before filing a notice of dispute. If they refuse, then file a notice of dispute.
    https://www.google.com/url?sa=t&sour...YxuMjvxmUCf_mw
    On another note, I would suggest that you install Tasker and set it to automatically disable mobile data when connected to wifi.
    Sent from my Verizon Samsung Galaxy Note 4
    Almeuit likes this.
    12-05-2014 09:49 AM
  9. doogald's Avatar
    I'm with others - I'd call back. It may be that they won't do anything until you actually have an overage - in other words, after you get billed call back (or have the family plan owner call) and insist on a credit for overages due to your phone's usage.
    See this post for reference: http://forums.androidcentral.com/mot...ml#post4060169
    Also, you can try what is supposed to be a temporary fix for now:
    1.) Turn wifi off
    2.) Turn airplane mode on
    3.) Turn wifi on (while still in airplane mode)
    4.) Turn airplane mode off
    I'd guess that you should do that every time you restart the phone. Maybe every time that you connect to a WiFi access point? It's be interesting to monitor usage going forward and see if that solves the problem...
    jeffreames likes this.
    12-05-2014 10:37 AM
  10. jesta192's Avatar
    ... On another note, I would suggest that you install Tasker and set it to automatically disable mobile data when connected to wifi...
    This is a great idea, but unfortunately the Verizon Visual Voicemail app is not capable of running on WiFi alone, so if you use it you won't get voicemails... Thanks Verizon.
    Also, I have seen at least one report that disabling mobile data does not stop the data leakage. So this may or may not work.
    12-05-2014 10:38 AM
  11. wsteske's Avatar
    I called Wednesday and kinda got the runaround also. They told me they didn't know of any issues with data. My phone is showing .49GB while Verizon is showing 1.38GB used in only 10 days. I've used between 1.5 and 2.25GB a month for the past 18 months. They finally told me they were giving it to a technician to investigate and I would receive a phone call back within 48 hours. I'm at hour 49........
    12-05-2014 11:31 AM
  12. doogald's Avatar
    I'd do the airplane mode fix from above while you wait for the call...
    12-05-2014 11:46 AM
  13. Vito2000's Avatar
    My brother and I both have the Droid Turbo. He has run into this issue and I have not. He called Verizon about it and the level 1 person had no idea that this is a known issue. Therefore he told my brother he must be unknowingly using mobile data instead of WiFi. My brother did not accept this and the call was escalated. The level 2 person knew about this issue and told my brother no overages would be billed to him this month regardless of how much data was used.
    So not everyone at Verizon is aware of this, but it is a known issue. Keep pushing until you get in touch with someone who knows about this issue and is willing to take care of it.
    Hgouck likes this.
    12-05-2014 11:53 AM
  14. tvouge's Avatar
    Since I'm on unlimited I don't normally pay attention, but my phone and the Verizon website are both reporting similar usage. I guess I'm not affected.
    12-05-2014 01:36 PM
  15. NoahForeman's Avatar
    I ckecked my usage as well, phone reports 630mb, VZW site reports 680mb. Pretty close, but I can see how small plans might have an issue.
    12-05-2014 02:23 PM
  16. jesta192's Avatar
    ... after you get billed call back (or have the family plan owner call) and insist on a credit for overages due to your phone's usage...
    I strongly recommend talking to Verizon *before* you have an overage. I fear that if you wait, Verizon will try to stick it to you. But if you notify them immediately that there is a serious discrepancy, the ball is in their court.
    12-05-2014 02:43 PM
  17. maxman1's Avatar
    I use so little data it's pathetic but even with my meager usage, the data reported by the phone vs. Verizon is substantial, almost double. Just to affirm that Verizon is aware of the glitch I called to report it. I spoke to a very nice young lady who, after a bit of digging, found documentation of the problem & said a fix was in the works involving both Motorola and Verizon. I'd urge anyone with data issues to call them, the more they understand it's a widespread issue the more likelihood of prioritizing a fix.
    Almeuit likes this.
    12-05-2014 03:45 PM
  18. Almeuit's Avatar
    Good to hear a fix is coming .
    12-05-2014 04:19 PM
  19. emock81's Avatar
    I am having the same problem. Phone reports about 325 MB through Wifi, about 1225 MB through data, but the My Verizon app is reporting about 1600 MB data so that's about half of the 3GB I'm allotted (normally 2, extra 1 promotional this month). I hope the fix comes soon. I have to monitor my usage. I don't reset until the 22nd.
    12-05-2014 07:48 PM
  20. Drachenfire's Avatar
    I have not experienced this issue on my Turbo.
    Have you insured your system software (not the Android version) is up to date? Mine is at 21.21.15.en.US.
    12-05-2014 07:51 PM
  21. maxman1's Avatar
    I'd call now...just in case you need documentation later.
    12-05-2014 08:18 PM
  22. MikeLip's Avatar
    I know this isn't the fix everyone is looking for, but I downloaded a widget to toggle mobile data. I didn't notice the data, but I *did* notice the battery usage - a lot of it was going to that radio, which made no sense because I almost never use data services when I am not under wifi. So there should have been nearly no battery usage from that radio. Instead it was nearly as high as screen usage giving me a pretty good hit on the battery. I toggle it off now when I'm under wifi and while it's an annoyance it's not major. And battery is where it should be.
    I note that the mobile data radio is off on my Moto X 14 when I am under wifi. So hopefully Lollipop will fix this. But since the Moto worked liked that on KK, it should work anyway. Heck, my Razr MaxxHD did that just fine. This was a stupid. major bug to allow to slip by!
    12-06-2014 12:35 PM
  23. nwasquad1's Avatar
    Would be curious to know about any updates
    12-06-2014 06:44 PM
  24. tdizzel's Avatar
    Customer service is a thing.
    I had to put that in its own sentence because it doesn't belong in the same sentence as Verizon.
    But yeah, like others have said, keep calling back until you get an answer that you like. Once you get an answer that you like make sure you politely inform the person who gave you that answer that it appears that there are other Verizon employees who are unaware of this issue and they might want to ensure that it gets communicated company wide that way you (maybe) won't have to deal with again when the bill comes because and you have overage charges.
    12-06-2014 07:24 PM
  25. Herbert Latten's Avatar
    When connected to WiFi make sure you have the "Restrict background data" box checked so you don't have any surprises and use opera mini as your primary browser. That's helped me lower my data usage.
    12-06-2014 09:08 PM
30 12
  1. Hold off on Lollipop upgrade?
    By Newfangled in forum Moto X (2014)
    Last Post: 01-22-2015, 09:09 PM
  2. Replies: 5
    Last Post: 01-05-2015, 07:36 PM
  3. How to unbrick a phone that won't power on?
    By FreakyLocz14 in forum Google Nexus 5
    Last Post: 12-05-2014, 09:38 PM
  4. What is this premium services.
    By flyer8493 in forum Sprint
    Last Post: 12-05-2014, 01:59 PM
  5. Replies: 1
    Last Post: 12-04-2014, 11:22 PM
