12-11-2014 12:45 PM
141 1234 ...
tools
  1. KSDroid01's Avatar
    Drop it on my Qi every night. On rare extremely heavy days I'll give it a bump with the turbocharger.
    Posted via the Turbo
    12-02-2014 12:44 AM
  2. mobrules's Avatar
    I usually charge at about 50%. Depends on where I am at. Home is standard charger. Work is the turbo charger. I usually have a 15000 mah battery pack with me so I might use that also.
    12-02-2014 12:52 AM
  3. Ch4dders's Avatar
    When it needs it...
    I drop it on my Qi charger every night. If I need extra juice throughout the day, I'll throw it on the Turbo charger. I rarely let my battery go below 25%,just my preference.
    12-02-2014 12:01 PM
  4. Seremedy's Avatar
    Why do u use a regular charger ? To charge it mostly ?
    Posted from my 64 GB Droid Turbo black nylon
    12-02-2014 03:31 PM
  5. NoahForeman's Avatar
    Wireless Nokia DT910 Qi stand at night, Turbo car charger on the way home from work.
    When I am coming home from work I usually go from 60%-95%, and over night 65%-100%.
    I use my phone a lot, lol.
    Posted via the Android Central App on my Droid Turbo.
    12-02-2014 03:51 PM
  6. cbironman24's Avatar
    I put mine on a wireless charger at night. It's usually at 45% when I go to bed. Over thanksgiving weekend I was away and used the turbo charger. I really liked how quick the turbo charger was. I might start using that more.
    12-02-2014 04:50 PM
  7. 1Coopgt's Avatar
    Every night, regardless of what the battery percentage is.
    +1
    12-02-2014 06:53 PM
  8. Seremedy's Avatar
    Should i get the note 4 or droid turbo ?
    12-04-2014 08:08 PM
  9. keyzlife's Avatar
    posted from your droid turbo. Sounds like decision made.
    sent from my Samsung GALAXY Note® 4
    bassplayrguy and DJ Sandman like this.
    12-04-2014 08:10 PM
  10. dpham00's Avatar
    What are your needs?
    Sent from my Verizon Samsung Galaxy Note 4
    12-04-2014 08:19 PM
  11. Seremedy's Avatar
    Thinking about returning the turbo and getting the note 4 because the big screen
    12-04-2014 09:27 PM
  12. Almeuit's Avatar
    As dpham said .. What are your needs for your phone ?
    12-04-2014 09:45 PM
  13. derekfaircloth's Avatar
    I think asking that in a note 4 forum you might get a lot of note 4 answers lol
    Seriously though my note 4 puchase came down to the s-pen. Since the first Note it is my favorite feature.
    John 3:16
    12-04-2014 10:00 PM
  14. jdfry15's Avatar
    I returned my turbo for the note 4. Couldn't deal with no data and voice at the same time. I'm extremely happy with the note 4, much better in my opinion. Only thing better on the turbo is near stock os and active notifications.
    12-04-2014 10:09 PM
  15. donebrasko's Avatar
    That's the reason I returned mine. I miss the battery though. Android systems want killing my battery with the same apps installed
    12-04-2014 11:37 PM
  16. Seremedy's Avatar
    Well im going to return my droid turbo tomorrow for thr note 4. I dont like the sixe of the turbo, the screens too small. And battery isnt actually a huge difference because my dad has a note 4 and ive done some tests. Theres a diffrence but not huge. Smoothness does go to the turbo but also not by a lot and hoping samsung will clear som bloat later.
    12-05-2014 12:16 AM
  17. Seremedy's Avatar
    When do you guys usually charge your note 4 ? At a certain percentage or from like 15-20 or what ?
    Posted via Samsung Galaxy Note 4
    12-05-2014 10:40 PM
  18. Omer San Gabriel's Avatar
    Not a Note 4 user but i use Samsung S5. I always charge mine around 5-10%. I've also asked this question way back and people said that it does not matter. xD Charge it if you are going out and using it heavily even though it is still 50% they said.
    12-05-2014 10:46 PM
  19. tsells's Avatar
    It does not matter!!!!!
    iOSConvert2k14 likes this.
    12-05-2014 10:50 PM
  20. muzzy996's Avatar
    This.
    It's your phone, use it how you want to.
    I see no reason why someone should worry about lifespan impacts due to charging habits of a $30 user replaceable battery.
    For me, I top off frequently as its more important that I never run out of power.
    My usage is light, about an hour of screen on time per work day and another 2 in the evening. I end the night with between 50 and 80% depending on use and I'll pop it on the charger overnight to be at 100% when I pull it off at 6am.
    vasekvi likes this.
    12-05-2014 11:24 PM
  21. Seremedy's Avatar
    Lol i use my phone atleast 6+ hours a day.
    12-06-2014 12:06 AM
  22. muzzy996's Avatar
    Great! If that's the case then why not charge it when you have the chance? Nothing wrong with a quick top off mid day and then charging overnight.
    12-06-2014 12:50 AM
  23. only foryou's Avatar
    Every battery has a 500 life cycles... one life cycle is like u get down below 20% and charge it to full... this isjust for your info... As a note 4 owner, you should never worry about the battery, casue u can replace with the new one any other day, unlike most of the unibody flagships.... use the note 4 at your will, unleash the beast... i am using all the guesters , multitasking, LTE and wifi, GPS every thing on....and i charge my phone once a day....... Note 4 simply rocks..
    Omer San Gabriel and muzzy996 like this.
    12-06-2014 01:03 AM
  24. worwig's Avatar
    I always just full charge overnight, then I get a full day of use. I typically never need to touch a charger again during the day. (except when using as a GPS with the display at 100%)
    As mentioned, you get like 500 FULL cycles of life. But, if you recharged at 50%, you get more like 1000 cycles. Recharge at 75%, get 2000 cycles.
    Do not do deep discharges, unless that is what your day requires.
    Basically, full charge when it is convenient. You bought it to be convenient after all and the battery is easy to replace.
    12-06-2014 09:26 AM
  25. LaTuFu's Avatar
    The 500 cycles thing is not a fixed number. It is an expectation, or a possibility. Not a guarantee.
    Factors that impact the service life of your battery are temperature extremes, depth of discharge, and charge cycles.
    If you don't care about the lifespan of the battery because replacement batteries are cheap, then don't worry about it and use the phone as you need to for your lifestyle. Buy a replacement when the charge life begins to erode. But don't expect to reach 500 cycles either.
    If you want to maximize the service life of your battery, don't let it get too hot (like leaving it in a hot car or taking it out on the beach in the summer), and don't wait until it's dead or down to 5-10% to recharge.
    12-06-2014 09:51 AM
141 1234 ...
  1. Replies: 9
    Last Post: 12-09-2016, 03:08 PM
  2. Replies: 3
    Last Post: 03-11-2015, 08:54 AM
  3. Why does my Galaxy s5 mess up after updates and how do I fix it???
    By naturedoc in forum General Help and How To
    Last Post: 12-11-2014, 02:36 AM
  4. Replies: 2
    Last Post: 12-07-2014, 01:28 AM
