1. Johnny Fever's Avatar
    1- Is there a way to set up the display so that phone will unlock by waving hand over it and not having to swipe down to open
    2- Im not the hugest fan of the notifications blinking on the active display until checked. Is there a way to disable the recurrent blinking and set it up so that you can randomly just wave over it and see if you received any messages/notifications in the notification bar etc.?
    For me, a perfect scenario would be active display blinking a few times then stopping. Then later I can check it when I get time w/o it blinking itself to death...
    thx
    JF
    12-08-2014 05:58 PM
  2. VooDooCC's Avatar
    I don't think it blinks face down or in a pocket. So if nothing else, you could last it face down or maybe rig something to cover up the sensors.
    I do agree a clean solution to both of these.
    12-08-2014 08:39 PM
  1. Replies: 3
    Last Post: 12-09-2014, 09:52 AM
  2. great case and sd card for note 3
    By zaydabarber in forum Samsung Galaxy Note 3
    Last Post: 12-08-2014, 07:20 PM
  3. AT&T WiFi Login prompt won't display
    By XOMXTO in forum Samsung Galaxy S5
    Last Post: 12-08-2014, 05:21 PM
  4. Replies: 0
    Last Post: 12-08-2014, 04:44 PM
