12-19-2014 12:51 PM
436 ... 1112131415 ...
tools
  1. Furt's Avatar
    Has this always been in developer options? Maybe I never noticed it
    Attached Thumbnails Verizon Motorola Droid Turbo VoLTE or Simultaneous Voice and Data-10979.jpg
    12-12-2014 02:26 PM
  2. Ryp11's Avatar
    I had google voice as the default VM but now its VZW visual voicemail. Can't seem to change it either.
    12-12-2014 02:31 PM
  3. Clocks's Avatar
    Reduced shutter lag
    That would be great news
    12-12-2014 02:33 PM
  4. nedqadams's Avatar
    Don't want to jinx it but I thought I noticed a battery increase. Also seems like Active Notifications aren't as sensitive to movement as they were. I.e. I can move my phone subtly without triggering them.
    12-12-2014 02:33 PM
  5. fonger13's Avatar
    There's is definitely a battery improvement
    12-12-2014 02:42 PM
  6. jasoraso's Avatar
    You need to re-forward your unanswered calls etc to Google Voice. I think it takes 3 different fowards: *71xxx, *90xxxx, and *92xxxx
    12-12-2014 02:54 PM
  7. Toes Up's Avatar
    May be simply a "placebo effect" but I also think the Active Notifications are not as sensitive.
    12-12-2014 03:00 PM
  8. nedqadams's Avatar
    Saw the same thing.
    12-12-2014 03:10 PM
  9. 1901Madison's Avatar
    Battery is absolutely better. And it's significantly better, not just a minor improvement. Particularly the idle drain - very impressive.
    12-12-2014 03:23 PM
  10. HappyFunBall24's Avatar
    I think so, not 100% though. I don't quite remember going to that screen, but what I do remember is chuckling at the line on the developer options page that says "geeky stats about running processes". And that blurb is associated with 'process stats', so take it for what it's worth.
    12-12-2014 03:33 PM
  11. -Myk-'s Avatar
    I disagree about the battery, mine is going down faster and the phone is getting hotter. I am at 83% after 90 mins. All I have done was place 1 15 min call. 20 min of web surfing and played a few games of Othello. At this rate I will need to turn advance calling off.
    12-12-2014 03:35 PM
  12. HappyFunBall24's Avatar
    ^^ Folks on the Droid Maxx thread have said the Advanced Calling features drain the battery faster. Perhaps that's the case and it's just that idle drain is slower, I dunno?
    12-12-2014 03:42 PM
  13. mobrules's Avatar
    Wow do I ever agree with this. I have noticed a huge increase in battery. Gonna do a drain and see just how long I can get. Ill post photos sunday here and the battery life thread in case anyone's interested.
    12-12-2014 03:42 PM
  14. mobrules's Avatar
    I dont have advanced calling activated due to coverage in my area. So yes the idle drain is half what it used to be.
    12-12-2014 03:46 PM
  15. -Myk-'s Avatar
    I am now at 77% since my last post. I guess solitaire is a major battery drain.
    12-12-2014 03:56 PM
  16. rader023's Avatar
    I had to redo all of my google voice stuff. I actually even started with a new number because I couldn't get it to work.
    12-12-2014 03:59 PM
  17. Masheen's Avatar
    Process Stats. Yes. Its more accurate than the default battery stats and GSam.
    12-12-2014 04:03 PM
  18. tvouge's Avatar
    I'm seeing better battery, better wi-fi signal, a faster camera shutter speed, and louder call volume (had to turn it down actually).
    I'm going to play around with the camera more, but I think this update addressed most of the major issues with this phone.
    12-12-2014 04:11 PM
  19. -Myk-'s Avatar
    71% now
    12-12-2014 04:11 PM
  20. HappyFunBall24's Avatar
    That's definitely something to get excited about it. I just wished that VZW would put out a proper, detailed document on the enhancements and fixes. You would think with all of the improvements that they could use some additional positive press.
    jesta192 likes this.
    12-12-2014 04:13 PM
  21. -Myk-'s Avatar
    I just turned advance calling off on the phone and rebooted. Let's see if things are different now
    12-12-2014 04:19 PM
  22. mobrules's Avatar
    Probably not a bad idea to clean the cache and charge it up and then see. Just an opinion.
    HappyFunBall24 likes this.
    12-12-2014 04:33 PM
  23. ckelly33's Avatar
    Sound quality of the earpiece isn't as good - significantly so, There is a static-y sound when the person is peaking. THere is no static when they are silent (or there is no noise coming through). Hard to explain - no one else hearing this?
    12-12-2014 04:41 PM
  24. tvouge's Avatar
    I'm not getting the static from calls. Crystal clear.
    12-12-2014 04:58 PM
  25. -Myk-'s Avatar
    My phone is much cooler and the battery is draining as normal now that I turned advanced calling off
    12-12-2014 05:04 PM
  1. i want to buy zagg screenprotector or ghost amor
    By Joke Adema in forum Samsung Galaxy Note Edge
    Last Post: 12-15-2014, 06:15 AM
  2. How do I fix my default Calendar app (Sony Xperia Z3)?
    By Karim Abdelghani in forum General Help and How To
    Last Post: 12-15-2014, 01:21 AM
  3. Replies: 1
    Last Post: 12-14-2014, 07:08 AM
  4. Verizon Motorola Droid Turbo Unable to use Google voicemail w/ turbo
    By Billy Bixby in forum Motorola Droid Turbo
    Last Post: 12-14-2014, 01:58 AM
  5. Why is my SD card suddenly not appearing or usable?
    By Link91 in forum Samsung Galaxy S4
    Last Post: 12-14-2014, 12:05 AM
