1. hal1's Avatar
    Has any of you noticed any qi wireless charging with any particular cases. I have a Speck Candyshell which is on the thick-ish side.
    12-11-2014 02:01 PM
  2. Furt's Avatar
    It's been a weird time with chargers. It depends a lot more on the charger than the case for me. I have an otterbox commuter case which is a bit thick and with the Anker and Aukey Luna chargers, it works perfectly. But with the Powers charger, I can't get that thing to work even without any case.
    12-11-2014 02:31 PM
  3. hal1's Avatar
    I'll see how it goes with the Itian A6
    12-11-2014 02:39 PM
  4. rxgadget's Avatar
    Right now ask Turbo phones are having faulty battery results no matter what Qi charger you use.
    Example : I bought 2 Tylt Vu Qi chargers. I tried charging my phone at night from 30% and the battery showed 100% within 5 minutes. This happens no matter what level I start at. It stays showing 100% for almost the length of the "day". This has been confirmed using GSam, Battery Widget, and multiple other apps and forums confirm as well
    Sent using my Verizon Turbo charged 64GB Ballistic Nylon phone unfortunately with a case on back
    12-11-2014 08:46 PM
  5. macawmatt's Avatar
    Been using a PowerBot charger successfully most nights with an Otterbox Commuter case on my BN. It is more particular on placement when the case is on though compared to when it is naked.
    Posted via the Android Central App on a Nexus 10 running Lollipop
    12-12-2014 01:18 AM
  6. ReverendOD's Avatar
    I have the speck grip and my qi charger will not work through it. I have read that a 3 coil charger will work possibly....
    12-12-2014 10:23 PM
  7. hal1's Avatar
    12-12-2014 11:04 PM
  8. ricepatrol's Avatar
    Hi HAL1,
    Could you please give us an update?
    I also have a turbo (metallic black, not BN) with a candyshell grip, and am looking for an inductive charger that works. (My dealextreme random ind. charger I used with my S3 doesn't work, single coil AFAIK)
    Thanks!
    12-16-2014 11:12 AM
  9. hal1's Avatar
    The above Itian A6 Works perfect with my Speck Candyshell Grip, but maybe a little slow, not sure. About 20% per hour, which I guess is not that unusual with Qi charging . Vertically it's perfect, horizontally it almost perfect, just have to have it slightly off center to the left.
    12-16-2014 12:13 PM
  10. ReverendOD's Avatar
    Good to know.
    12-16-2014 09:08 PM
  11. ricepatrol's Avatar
    I can confirm, that this model does work! Thanks hal1 for the Intel!
    12-19-2014 09:50 AM
  1. Why isn't Twitter compatible with the Note Pro???
    By eobet in forum Samsung Galaxy Note Pro 12.2
    Last Post: 08-01-2017, 11:35 PM
  2. My experience with a magnetic clip case. DO NOT BUY
    By lpcs1 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 12-28-2014, 06:05 PM
  3. Is there any way to change the calendar format?
    By Rikku Watro in forum Ask a Question
    Last Post: 12-15-2014, 01:22 AM
  4. How do I fix my default Calendar app (Sony Xperia Z3)?
    By Karim Abdelghani in forum General Help and How To
    Last Post: 12-15-2014, 01:21 AM
  5. How do I remove an app icon from the Home screen with UMI C1?
    By antoninos59 in forum Ask a Question
    Last Post: 12-15-2014, 01:10 AM
