1. SevenDBO's Avatar
    When I open chrome from time to time, I get a pop-up to the play store for random apps. It is pretty bothersome to me, and I am a bit worried. I've done a full scan and haven't detected anything, but it did not do this for the first 2 weeks I had the phone (got it oct 30th release date) but has been for a bit, even after cache partition clear and ota update today. Any help or insight would be great!
    12-12-2014 02:36 PM
  2. Rukbat's Avatar
    The only thing you can redirect is the address, and if you redirect the address of the Play Store, you won't be able to use the Play Store on that phone. (You can't easily redirect it only in Chrome, you have to redirect it for the phone.)
    A popup blocker in Chrome might work, though - if it doesn't work by modifying the hosts file (which is how most work, and which creates the first problem, since the hosts file is used by the whole phone).
    12-12-2014 03:05 PM
  3. doogald's Avatar
    I'll bet that you opened a page in Chrome that had a redirect to the Play Store, and it keeps opening that page when you re-open Chrome (Chrome remembers the tabs that are open). Go back to Chrome (using the running tasks button, bottom right), hit the square control on the top right (the running tabs button), and swipe away any tabs that are open.
    See if that helps.
    If it doesn't, try settings / apps, scroll to Chrome, and "clear data" rather than "clear cache".
    12-12-2014 03:33 PM
  4. pdaniel219's Avatar
    See if that helps.
    Yep, that happened to me and I did just what doogald described. I had opened a web page with that play Playstore app page and I was always redirected to that. I didn't notice it at all when I opened up chrome, cause I almost always use Google now. After I closed that tab in chrome it stopped happening.
    12-12-2014 04:21 PM
  5. SevenDBO's Avatar
    Thanks very much guys! I clears the data from the settings-apps-chrome. That did the trick. Much appreciated.
    12-13-2014 06:20 PM
  6. opus1269's Avatar
    Happens to me sometimes. It is a new trend in intrusive ads.
    12-14-2014 08:50 AM
  1. Replies: 37
    Last Post: 10-19-2016, 09:56 PM
  2. best way to charge X
    By ezzzzz in forum Moto X
    Last Post: 12-15-2014, 06:01 PM
  3. i want to buy zagg screenprotector or ghost amor
    By Joke Adema in forum Samsung Galaxy Note Edge
    Last Post: 12-15-2014, 05:15 AM
  4. Replies: 1
    Last Post: 12-15-2014, 12:27 AM
  5. Is there any way to change the calendar format?
    By Rikku Watro in forum Ask a Question
    Last Post: 12-15-2014, 12:22 AM
