1. anon(9228075)'s Avatar
    Came from S4 and love the Droid Turbo. Still feeling my way around. One thing I've noticed is an issue when I'm using the phone via bluetooth or wired headset for calls. In my office I use bluetooth or wired headset and the screen will go black during the call after the timeout time hits, but lots of times I need to access email or something during the call ... So how do you turn the screen back on? On S4 you just hit the button at the bottom but since these aren't true "push buttons" nothing happens.
    Same thing happens when ending a call that on a headset when they screen is black - how do you hang up?? I've been waiting and letting other person hang up. The " approach the screen motion" doesn't seem to wake it up during a call.
    Thanks in advance.
    12-12-2014 05:57 PM
  2. Rukbat's Avatar
    The screen should wake up if you tap the power button. And if you press the BT headset button during a call it should hang up.
    12-12-2014 06:17 PM
  3. HappyFunBall24's Avatar
    Welcome, and great phone choice! Pressing the power button brings up the screen. You can then go to the notifications bar to quickly hang up, if the dialer is not already on screen. (EDIT: I'm slow on the draw, beaten to the punch again!)
    12-12-2014 06:22 PM
  4. anon(9228075)'s Avatar
    Thanks. Yeah, can hangup via bluetooth button, no problem.
    Just figured out pushing the side power button. So just now was on call, had to reach around to side and push that in to wake up - inconvenient button to push for sure. That's annoying oversight. Especially the part about being on a call and needing to wake it up to look for something. Much easier to mash a button down while its laying there than to have to grab both sides and basically pick it up to be able to push it... 1st world problems huh lol
    12-12-2014 06:33 PM
  5. Jonahsdad's Avatar
    I tried waking up my screen, after being on hold for 23 minutes, by hitting the power button. The call immediately ended.
    05-26-2015 01:19 PM
  6. maxman1's Avatar
    That is an option in settings. By default, the phone is set to wake screen via power button but can be changed to hang up.
    05-26-2015 02:02 PM
  7. doogald's Avatar
    Namely, it's in settings / accessibility / power button ends call (uncheck that.)
    05-26-2015 02:08 PM
  1. Nexus 7 (2012) WIFI only - Bots in "Erasing" screen only
    By zoomzoomvince in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-24-2015, 07:59 AM
  2. no wifi after kitkat 4.4.2 update
    By Jesse Labadlabad in forum ASUS Fonepad 7
    Last Post: 12-29-2014, 09:26 AM
  3. How do I fix my default Calendar app (Sony Xperia Z3)?
    By Karim Abdelghani in forum General Help and How To
    Last Post: 12-15-2014, 01:21 AM
  4. How do I remove an app icon from the Home screen with UMI C1?
    By antoninos59 in forum Ask a Question
    Last Post: 12-15-2014, 01:10 AM
  5. What Should Android Device Manager's Unlock Screen Look Like?
    By Slarti Bartfast in forum Ask a Question
    Last Post: 12-15-2014, 01:06 AM
