1. 1Coopgt's Avatar
    Has anyone managed to get it working on the Turbo? I picked up a 64gb Sandisk USB jumb drive that should work with the turbo but no go so far .
    12-12-2014 08:14 PM
  2. srkmagnus's Avatar
    I did some looking around and yes, it does support external USB storage. You'll need an OTG cable or adapter to allow you to connect the expandable memory to the Turbo. Let us know how it goes.
    12-12-2014 10:56 PM
  3. doogald's Avatar
    If the 64 GB drive is formatted NTFS, you'll need to reformat it as FAT32 to get it to work, I believe. I know that there is a single file size limitation of 4 GB for FAT32, but I can't recall if FAT32 supports partitions as large as 64 GB - but I think it does...
    12-13-2014 10:34 AM
  4. 1Coopgt's Avatar
    Hmmmm the Scandisk 64GB is formatted in EXFAT . I can only format it in NTSF or ExFAT on my laptop . Not sure if its a limitation of Win 8.1 .
    12-13-2014 11:27 AM
  5. doogald's Avatar
    Yep. I think Windows doesn't like to format FAT32 for partitions that large.
    See this post on androidforums, where I think you'll find a solution: http://androidforums.com/threads/max.../#post-6820479
    12-13-2014 11:32 AM
  6. 1Coopgt's Avatar
    Got it fixed . Had to download a program to Format the 64gb thumb drive to Fat 32 . Works great now .
    12-14-2014 10:56 AM
  7. Jon Graham's Avatar
    May I ask what formatting utility you used? I have Windows 8 also and I just bought a Droid Turbo and would like to use the external storage capability.
    06-01-2015 07:17 PM
  8. Quatro44's Avatar
    What program did you download
    11-19-2016 12:09 AM
  9. 1Coopgt's Avatar
    Unfortunately I can't remember ,this was 2 yrs ago . I did a google search on free programs that would format to fat32 .
    11-19-2016 07:08 AM
  10. quantum tao's Avatar
    just use windows , format the drive and pick fat32 as the file system
    11-19-2016 12:29 PM
  1. Why isn't Twitter compatible with the Note Pro???
    By eobet in forum Samsung Galaxy Note Pro 12.2
    Last Post: 08-01-2017, 10:35 PM
  2. text on some websites cut off
    By Zakappel in forum Google Nexus 7 Tablet (2012)
    Last Post: 06-20-2017, 04:20 AM
  3. How do I remove an app icon from the Home screen with UMI C1?
    By antoninos59 in forum Ask a Question
    Last Post: 12-15-2014, 12:10 AM
  4. Why is the installed SD not detected?
    By Tita Weng Bay Meris in forum General Help and How To
    Last Post: 12-14-2014, 11:16 PM
  5. When was Samsung Galaxy S (the first one) released?
    By Rikku Watro in forum Ask a Question
    Last Post: 12-14-2014, 03:56 PM
