02-18-2015 10:40 PM
101 123 ...
tools
  1. anon(9228075)'s Avatar
    What are you guys using? I e used SwiftKey forever but gave the stock Google one a shot and really liked it.
    Only reason I put the SwiftKey back on was the #'s on top row and I like the question mark option on the "." key where you can swipe to the right and get a "?"
    M
    12-13-2014 06:32 PM
  2. Rukbat's Avatar
    I don't swipe (I've tried it, but just can't get the hang of it), but I use Swiftkey without the number row on top (I can long-press a key easily enough). I can make do with the stock keyboard if I have to, but I'm more comfortable with Swiftkey - know where all the long-press characters are, the spacing of the keys, etc.
    12-13-2014 06:38 PM
  3. mightyfacundo's Avatar
    SwiftKey for me. It has given me no reason to try another keyboard.
    hannsoft likes this.
    12-13-2014 06:46 PM
  4. Bitterman's Avatar
    I've been using Swype since it's beta days and now use the paid version. I set up my wife with the google KB on her Maxx. I'm so used to "swyping" that it find it hard to peck on a normal KB.
    12-13-2014 06:47 PM
  5. HappyFunBall24's Avatar
    Big Swiftkey fan. Lots of customization, including all of the sizing and style options and the aforementioned number row. I also think that their word predictions are better, but that could be bias talking.
    12-13-2014 06:59 PM
  6. CharlieL3's Avatar
    I use hacker's keyboard. I like the arrow keys and the Ctrl and Alt keys.
    12-13-2014 07:31 PM
  7. kmf1's Avatar
    I've been very pleased with SwiftKey for several years now.
    12-13-2014 08:16 PM
  8. vegasdroid's Avatar
    I've used SwiftKey ever since it came out. I'll never use another keyboard.
    12-13-2014 08:55 PM
  9. Eclipse2K's Avatar
    I am the rare person that actually prefers Google Keyboard (stock). It just works well, great auto correct and I love the key positioning.
    Sent from my Motorola Droid Turbo
    neonworm likes this.
    12-13-2014 09:04 PM
  10. anon(9228075)'s Avatar
    I don't Swype either. I turned it off in case my finger accidentally slides across the keyboard.
    For all you SwiftKey guys, how is it the paid version themes, if you've used?
    12-13-2014 11:24 PM
  11. hal1's Avatar
    I've never had any need to look any further than Swiftkey. I love its number row, auto-correct, intuitive learning and swyping when I chose. There may be better options but I've never had the need to look. It's not just its autocorrect, but its intuitive learning of my writing style and memory of past words and phrases that I use.
    KPMcClave and vegasdroid like this.
    12-13-2014 11:24 PM
  12. Billy Bixby's Avatar
    Search "google keyboard number row" You can play with the settings and have numbers in top row of keyboard.
    leehardballer12 likes this.
    12-13-2014 11:25 PM
  13. vegasdroid's Avatar
    They have, a lot of great options for the theme of the keyboard to match your them of your phone. I think, that it's worth taking a look at it.
    12-13-2014 11:45 PM
  14. Bamzilla's Avatar
    I use SwiftKey. I like the number row and easy symbol access. I coach track and text or type a lot of times/distances so quick access to : and - are very handy. The learning is great to as I don't have to type out whole words. The swiping works well too when one handed.
    Sent from my XT1254 using Tapatalk
    12-13-2014 11:49 PM
  15. KPMcClave's Avatar
    SwiftKey all the way here. When I got my first Android a year and a half ago, I came from 7 years of BlackBerry physical keyboards on various models. Nothing compares to that as a typing experience, but SwiftKey is the best for me for typing on glass.
    I've tried other options (Fleksy, etc.) along the way just to compare, and always wind up back with SwiftKey quickly.
    12-14-2014 12:03 AM
  16. VooDooCC's Avatar
    I've been using Swype since the beta days as well. I've tried many others, including swiftkey, but keep coming back to Swype. Only thing I wish it had is an arrow row, but long pressing to get to it isn't a deal breaker
    12-14-2014 12:15 AM
  17. JimBen73's Avatar
    I really like Minuum keyboard, been using this past year exclusively
    sent turbo fast
    12-14-2014 12:25 AM
  18. hal1's Avatar
    Thanks for reminding me. That's another huge plus for Swiftkey
    12-14-2014 12:49 AM
  19. KSDroid01's Avatar
    I've used and loved Swype since it's beta days, but got frustrated over its lack of emojis, so when I got my Turbo I tried, the standard keyboard and find it astonishingly just as good for me as Swype was. I've got it set up to convert to a version with a dedicated number row when I need it, which I couldn't do with Swype.
    Posted via the Turbo
    12-14-2014 12:59 AM
  20. rxgadget's Avatar
    I am addicted to SwiftKey keyboard or I am also in their beta testing so my alternate is SwiftKey Beta
    Sent using my Verizon Turbo charged 64GB Ballistic Nylon phone unfortunately with a case on back
    12-14-2014 06:28 AM
  21. KPMcClave's Avatar
    I wish they didn't have a separate installation for the Beta version. Especially since SwiftKey's Beta has had some genuine cool features to test out in advance. That SwiftKey and Chrome do this bugs me. My phone already has enough "extra" stuff without carrying two versions of big apps.
    12-14-2014 06:54 AM
  22. dungoyle's Avatar
    I did this, and the implementation was rather painful. I don't use swiftkey (presently), so I can't compare their numbers row to the implementation in the goggle keyboard, but the google implementation was definitely not for me, and based on other user's remarks, that seems to be the general consensus.
    12-14-2014 10:51 AM
  23. mimsiesboy's Avatar
    I am a SwiftKey user, it's been a few years now and I have tried others but I always come back, now on my nexus 7 I do not like SwiftKey for tablets, using the Google keyboard set pc style. In this configuration the numbers are on the top row.
    12-14-2014 11:04 AM
  24. PowrDroid's Avatar
    It's SwiftKey for me.
    12-14-2014 11:25 AM
  25. 1Coopgt's Avatar
    I'm using AI.TYPE KEYBOARD Plus . A lot of different themes plus you can use your own back grounds .
    Attached Thumbnails Verizon Motorola Droid Turbo Stock keyboard or SwiftKey?-screenshot_2014-12-14-11-32-20.png
    Jay Sacks likes this.
    12-14-2014 11:38 AM
101 123 ...
  1. i want to buy zagg screenprotector or ghost amor
    By Joke Adema in forum Samsung Galaxy Note Edge
    Last Post: 12-15-2014, 06:15 AM
  2. Droid Bionic, (no sim) wont download anything??
    By squishsquish in forum General Help and How To
    Last Post: 12-15-2014, 12:55 AM
  3. Replies: 1
    Last Post: 12-14-2014, 07:08 AM
  4. Verizon Motorola Droid Turbo Unable to use Google voicemail w/ turbo
    By Billy Bixby in forum Motorola Droid Turbo
    Last Post: 12-14-2014, 01:58 AM
  5. Why is my SD card suddenly not appearing or usable?
    By Link91 in forum Samsung Galaxy S4
    Last Post: 12-14-2014, 12:05 AM
