1. Dhawk1202's Avatar
    Since I've downloaded the update, my phone will put itself into silent mode all by itself. If I have it on vibrate or loud, it doesn't matter it will find itself back to silent. Any ideas?
    12-14-2014 02:19 PM
  2. ckelly33's Avatar
    Mine has been doing this since before the update. I think (in my case) it has to do with using apps that automatically silence when you drive, when you sleep, etc but actually don't consistently return the phone to its previous volumes. Are you using anything like that?
    12-14-2014 02:45 PM
  3. Dhawk1202's Avatar
    No. I use Tasker but not currently using any profiles to create this action. Weird. Never once had this problem before update.
    12-14-2014 02:53 PM
  4. ckelly33's Avatar
    yeah, we had a thread going on it for a little while (before update)
    http://forums.androidcentral.com/mot...ml#post4082975
    12-14-2014 02:57 PM
  5. StormnNJ's Avatar
    Mine isn't going "silent" it just isn't notifying me I received a text or email. Some sound most don't. Other thing is moto isn't notifying me either.
    12-14-2014 03:34 PM
  1. Way(s) to shoot a video with Droid Turbo for >30 minutes?
    By rhayden31 in forum Motorola Droid Turbo
    Last Post: 01-13-2015, 05:13 PM
  2. Replies: 3
    Last Post: 12-31-2014, 12:50 AM
  3. Can we try and clarify the hissing issue with the new update?
    By Johnny Fever in forum Motorola Droid Turbo
    Last Post: 12-16-2014, 08:20 AM
  4. 4.4.4 Update
    By jvcalandra1030 in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 12-15-2014, 08:25 PM
  5. Is Moto Voice just the middleman to get to google?
    Last Post: 12-15-2014, 10:34 AM
