Battery usage timer not reset fter full Qi charge
hal1
1,269
8
Is it normal that the battery timer reset, where it states how long since removed from the charger, doesn't reset after being removed from a Qi charger. I have the Itian A6
EDIT: Okay, it seems to work from a full charge, but not if taken off before 100%
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
That number is only useful to you, it has nothing to do with the phone. Is it normal to not reset? No. Will it cause any problem if it doesn't? No. Charging isn't done by time, it's done by charge state.
hal1
1,269
8
I know, it's just that it's nice to see your usage since last full charge. That's okay, like I edited, it does indeed reset after a full charge.
Jan
