1. stimulatedboredom's Avatar
    I've never had this issue with any of my previous phones, but if I'm using a Bluetooth device (headphones, speaker) near a microwave that's heating something, the Bluetooth is unusable and just incessantly skips and cuts out.
    Again, never had this issue with any other phone but the Turbo...curious if anyone else has experienced it and is it just weak Bluetooth on the phone?
    12-17-2014 08:34 AM
  2. teeitupmo#WN's Avatar
    Dude..that's your imagination. Seems like everyone is manufacturing problems with the Turbo. I use BT all the time at work and at home with my Turbo...no issues. Three people at work have Turbos...no issues.
    Sent from my iPhone using Tapatalk
    12-17-2014 08:53 AM
  3. doogald's Avatar
    Microwaves use the same 2.5 Ghz bandwidth that Bluetooth and WiFi uses. It's not uncommon for them to interfere.
    stimulatedboredom and dmark44 like this.
    12-17-2014 09:56 AM
  4. hal1's Avatar
    Always had interference with my bluetooth by a microwave for any phone for many years
    stimulatedboredom likes this.
    12-17-2014 10:16 AM
  5. CharlieL3's Avatar
    The solution is easy. Take the phone out of the microwave when you're on a Bluetooth call and heating something up.
    12-17-2014 11:21 AM
  6. stimulatedboredom's Avatar
    Excellent, that's the helpful response I was looking for, thank you.
    My HTC One (M7) and Nexus before it never had this issue.
    Context: I throw on BT headphones every morning when I take the dogs out, then come in and grab my coffee and heat up tea for my girlfriend. With the Turbo, everytime I heat up the water is when the signal goes to hell. Not a big deal, was just curious if it was an issue anyone else had.
    12-17-2014 12:43 PM
  7. stimulatedboredom's Avatar
    12-17-2014 12:43 PM
  8. stimulatedboredom's Avatar
    Thanks, good to know it's not just me / issue with only my phone.
    12-17-2014 12:43 PM
  9. stimulatedboredom's Avatar
    <sarcasm>
    Yes, the consistently replicated experience that I'm having in which there is an immediate and direct correlation between turning on my microwave and my Bluetooth signal immediately dropping and skipping is "imaginary" & "manufactured."
    </sarcasm>
    12-17-2014 01:22 PM
  10. graygr's Avatar
    Really...don't use your phone while cooking! Problem solved!
    12-18-2014 01:50 AM
  1. Why SD card cause my phone to vibrate randomly?
    By acsurfer in forum General Help and How To
    Last Post: 12-18-2014, 12:33 PM
  2. Replies: 1
    Last Post: 12-16-2014, 10:52 PM
