1. kkhanmd's Avatar
    Which of the two phones is stronger without a case in case of a fall?
    12-17-2014 05:19 PM
  2. HappyFunBall24's Avatar
    ^^ For whatever reason, I read that and suddenly had movie-trailer-voice-guy in my head: "Two will enter, one will leave!"
    I've heard that the BN-version has a Kevlar backing underneath - but not sure if that's true. If so, then I would think that durability is quite similar. Good question though, wonder if anyone will sacrifice 2 poor DT's to find out...
    xweb10 likes this.
    12-17-2014 05:30 PM
  3. ckelly33's Avatar
    I can vouch for the BN. I've dropped it at lease twice on concrete+tile from 4 feet. Maybe I'm just lucky.....
    12-17-2014 05:44 PM
  4. RT6's Avatar
    Mine fell out of my chest coat pocket onto asphalt and didn't even leave a scratch. That same fall is what cracked the screen on my RAZR HD. I was pretty impressed.
    12-17-2014 06:00 PM
  5. Bamzilla's Avatar
    Dropped my nylon Turbo once in a parking lot and it held up great. Just a small nick on the side plastic frame. You have to look close with light reflection to see
    Sent from my XT1254 using Tapatalk
    12-17-2014 08:47 PM
  6. kkhanmd's Avatar
    RT6 do you use BN?
    12-17-2014 09:18 PM
  1. Sandisk vs Samsung: Which SD card is best?
    By SoundofReason in forum Samsung Galaxy Note 4 Accessories
    Last Post: 11-23-2017, 02:06 PM
  2. Replies: 2
    Last Post: 01-05-2015, 10:31 PM
  3. Can the My Files Timeline be disabled or default settings changed
    By tsimitpo in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 12-20-2014, 10:44 PM
  4. Replies: 0
    Last Post: 12-17-2014, 05:06 PM
  5. When will 5G be available?
    By Rikku Watro in forum Ask a Question
    Last Post: 12-17-2014, 01:38 PM
