1. Billy Bixby's Avatar
    I have not been getting any notifications for incoming emails on my DT. I have double checked my account settings, gmail settings-everything is set to ON. Anyone else having this issue or know a fix? If i refresh/open my gmail they show up, but alerts would be nice.
    12-17-2014 06:46 PM
  2. Gekko's Avatar
    i've had this problem in the past and it was because GCM (Google Cloud Messaging) was broken. no push services. the only fix was a hard reset back to factory fresh state and then a manual resync/reinstall of everything. be sure you back up all of your data first. good luck.
    12-17-2014 06:50 PM
  3. Billy Bixby's Avatar
    Ouch.
    12-17-2014 07:04 PM
  4. mariongiant's Avatar
    Did you do the advanced calling update? When I turned that on, it took several hours for Gmail notifications to come through. All the settings were correct, and eventually the problem took care of itself.
    12-17-2014 10:08 PM
  1. Replies: 2
    Last Post: 01-05-2015, 11:31 PM
  2. Mobile Hotspot Issue Caused by Advanced Calling Update
    By Sean Cogan in forum Motorola Droid Turbo
    Last Post: 12-29-2014, 07:33 PM
  3. Replies: 6
    Last Post: 12-19-2014, 04:51 PM
  4. Can not respond or see Facebook notifications...
    By Ramsin Essapour in forum Samsung Gear S
    Last Post: 12-17-2014, 11:13 PM
  5. Help with notification screen.
    By Frank Visconti in forum LG G3
    Last Post: 12-17-2014, 06:24 PM
