OK so I have been testing the device. And I am basing this off of the observation that there are 3 'similar' appearing sensors in the corners of the device: 2 on bottom and 1 on top right. Which I think are the sensors of interest to activate the screen.
It seems that the TOP RIGHT corner is the most sensitive. I can activate the display whether I am 6 inches or 1millimeter above the device.
The other bottom ones will NOT activate the device if you are very close, I.e., just barely hovering over the screen. The device will activate if you are about 4 inches above. Anything closer will not activate it no matter how fast or slow you move over it.
Is this what others have noticed?
Jf
Jf
