1. Johnny Fever's Avatar
    OK so I have been testing the device. And I am basing this off of the observation that there are 3 'similar' appearing sensors in the corners of the device: 2 on bottom and 1 on top right. Which I think are the sensors of interest to activate the screen.
    It seems that the TOP RIGHT corner is the most sensitive. I can activate the display whether I am 6 inches or 1millimeter above the device.
    The other bottom ones will NOT activate the device if you are very close, I.e., just barely hovering over the screen. The device will activate if you are about 4 inches above. Anything closer will not activate it no matter how fast or slow you move over it.
    Is this what others have noticed?
    Jf
    12-18-2014 04:01 PM
  2. luke31's Avatar
    Jf
    The same applies to my Moto X. I heard that the bottom things aren't sensors, just emitters which"deflect" to the top, where the real sensor is. Don't know how accurate this is, but it makes sense.
    12-18-2014 04:40 PM
  1. Why can't I SMS on my Note 4?
    By ingridn in forum Samsung Galaxy Note 4
    Last Post: 11-08-2015, 05:37 PM
  2. nova on note 4
    By dave3389 in forum Samsung Galaxy Note 4
    Last Post: 12-26-2014, 09:42 AM
  3. Replies: 1
    Last Post: 12-18-2014, 03:24 PM
  4. Give some info on Dalvik vs ART
    By naresh bathula in forum Samsung Galaxy S5
    Last Post: 12-18-2014, 02:21 PM
