1. PowrDroid's Avatar
    I want to complain about a couple of things regarding using the camera itself.
    1. When taking pictures in landscape mode (practically always, for me) the power button is in an awkward place. That place seems to be the natural spot to rest your left index finger while you are framing/taking the shot. I've learned I have to remember to keep my left index finger on the very corner of the phone's body.
    2. After taking the photo there is no small gallery window on screen to tap and instantly review the shot. Instead, you have to swipe right-to-left to pull up your last shot. Many, many times I pull up Google Now instead of the picture in the gallery. This means I have to remember to precisely swipe the area between the Android home button and the Recent Apps button to see the pic. An alternative is to rotate the phone into Portrait mode, swipe right-to-left, then reposition in landscape mode, but that is awkward and should be unnecessary.
    Otherwise, I'm OK with the camera. It has the usual shortcomings (as all phone cameras) in low light situations and low light with movement but otherwise is a pretty good shooter. Definitely better than my previous Maxx HD and my son's previous Moto X.
    12-19-2014 09:44 AM
  2. doogald's Avatar
    Hold your phone the other way when you take photos, with the cap buttons to the left and the power button on the bottom. That should solve both the left index finger and the swipe to open gallery problems.
    12-19-2014 10:33 AM
  3. VooDooCC's Avatar
    The swipe for gallery works anywhere on the screen for me.
    12-19-2014 10:37 AM
  4. PowrDroid's Avatar
    I'm accustomed to having the buttons on top because with my Maxx HD I had the volume button assigned as the shutter. This is useful in low light conditions because you can hold the phone steadier with both hands and merely release the volume rocker to take the shutter, rather than holding with one hand and tapping the screen. Still, I might give your technique a try out.
    12-19-2014 11:06 AM
  5. PowrDroid's Avatar
    Arrghh! Yes, yes, it does. Thank you.
    12-19-2014 11:07 AM
  6. NoahForeman's Avatar
    My problem is that after I take a picture however I am holding it tells the phone it's stowed in a pocket and closes the camera :/
    Posted via the Android Central App on my Droid Turbo.
    12-19-2014 11:15 AM
  7. xweb10's Avatar
    How do you accomplish this? Any specific app?
    12-19-2014 12:40 PM
  8. PowrDroid's Avatar
    This was a feature of the stock camera app on the Maxx HD. It was in the settings menu. Helped a lot with blurry photos in low light. Don't see it on the stock Turbo camera. I don't think it's on Google Camera either (not sure). It is on A Better Camera, which I have installed, and it's on Camera FV-5.
    xweb10 likes this.
    12-19-2014 02:35 PM
  9. doogald's Avatar
    Unless something is different about the Turbo, the stock Moto camera app will capture a photo when you press either of the volume buttons. The Google camera app will as well. It's not a setting - it just works.
    PowrDroid and ghbishop like this.
    12-19-2014 02:39 PM
  10. PowrDroid's Avatar
    Yes, you are correct. Volume button does work as shutter in stock Turbo camera. However, I can't use my trick of having the shutter engage when releasing the volume button as I could with my Maxx HD.
    12-19-2014 02:42 PM
  11. 1BlinkGone's Avatar
    My Droid Turbo DOES engage the shutter when releasing the volume button. Works like a charm. BTW, this was with the Google Camera app. Thanks for the tip!
    12-20-2014 09:46 PM
  12. ghbishop's Avatar
    My Volume Up takes a single shot when held down - Volume Down takes burst mode when held down - 10 shots.
    This is a much better way to take a picture than tapping the screen.
    jesta192, KWildman001 and doogald like this.
    12-21-2014 11:13 AM
  13. PowrDroid's Avatar
    Weird. Mine does burst mode for either volume up or volume down.
    jesta192 likes this.
    12-21-2014 06:02 PM
  14. PowrDroid's Avatar
    Good to hear. I think it's a great feature and I really miss it. Might be a reason to use Google camera app.
    12-21-2014 06:03 PM
  15. VooDooCC's Avatar
    Mine too.
    12-21-2014 10:16 PM
  1. Noticed something kind of cool about the express me panels
    By EsEllEmm in forum Samsung Galaxy Note Edge
    Last Post: 08-29-2015, 02:10 AM
  2. Replies: 2
    Last Post: 12-21-2014, 11:28 PM
  3. Dropbox "Camera Uploads" album not viewable in Gallery app
    By blaidan in forum Samsung Galaxy Note 4
    Last Post: 12-21-2014, 08:15 PM
  4. How can I contact you geniuses about PixieGames post?
    By PixieGames in forum Ask a Question
    Last Post: 12-19-2014, 04:53 PM
