dss2000
Well I got the case off. For anyone else using the Surface case on the 64GB Turbo, the case fits, quite snuggly. I had to use my leg as leverage when pushing on the release button. But it came off.
Posted from 64GB BN Droid Turbo
If you pinch the sides of the half without finger grip near the seam the cover will bow slightly disengaging the catch and it slides off easily.
