1. mmpotash's Avatar
    I've had my Turbo 3 days and love it, plus received a $100 credit when I called about the price change as of yesterday... now $99. But one issue bothers me. I keep receiving a "Location Found" notification. I want to keep the GPS on for nav. How can I have it on and stop receiving the notification?
    12-22-2014 11:14 AM
  2. VooDooCC's Avatar
    I turned off the Moto assist for driving and home, that seems to have cured it for me.
    12-22-2014 12:18 PM
  3. mmpotash's Avatar
    I like the Moto Assist part that reads texts while driving so I was hoping there was another way. I'll try turning off notifications in the "Moto" settings.
    12-22-2014 12:34 PM
  4. GatsbyGlen's Avatar
    I've been seeing this when I have GPS set to high accuracy mode, which I use when driving. Otherwise, I change it to Battery Saving.
    12-22-2014 12:45 PM
  5. mrcraft2u's Avatar
    I also think that the "location found" notifications are for the Google Now screen that detects where you last parked. It displays it as a Google Now Card with a map of approximately where you parked.
    12-22-2014 04:38 PM
  6. quantum tao's Avatar
    Under location settings you can tap on the different location services to open them. Some have a "show notifications" check box you can uncheck.
    12-23-2014 09:35 AM
  7. JamesThomas936's Avatar
    That's just the NSA letting you know they found you!
    12-23-2014 09:01 PM
  8. kirksucks's Avatar
    Unchecked all notification boxes I could under location and its still popping up.
    02-15-2015 02:28 AM
  9. kirksucks's Avatar
    my commute is 12 minutes across town and I dont travel very often so I switched from high accuracy to battery saving. I'll let you know how it goes.
    02-18-2015 10:47 AM
  10. kirksucks's Avatar
    So far so good.
    02-18-2015 08:47 PM
  11. Philipmom's Avatar
    I long pressed on the notification and it was GPS notifier. I just did a force stop and will see how it effects anything.
    02-20-2015 08:19 PM
  12. lachlan waterbury's Avatar
    Ssssshhhhh
    11-17-2016 08:47 PM
  1. notification bar icons...
    By Marcin Stachurski in forum Samsung Galaxy Note 3
    Last Post: 12-23-2014, 12:17 AM
  2. Replies: 3
    Last Post: 12-22-2014, 09:08 PM
  3. Why are my notifications appearing so fast?
    By PlanetPluto7 in forum ASUS ZenWatch
    Last Post: 12-22-2014, 12:13 PM
  4. is therea to add notification sound when you with your fingerprint?
    By icellphones32 in forum Samsung Galaxy Note 4
    Last Post: 12-22-2014, 10:11 AM
