10-06-2015 11:10 PM
53 123
tools
  1. beeztrain's Avatar
    I have an iottie wireless charger for my car. It drives the phone crazy! It becomes extremely laggy and the battery begins to drain rapidly afterward. Oddly enough even when the dock isn't plugged in and I just use it as a cradle it does the same thing. If I use my regular holder nothing happens. Very strange indeed.
    09-26-2015 05:44 AM
  2. leehardballer12's Avatar
    I have the TYLT charger located in a central, convenient location in my house. I throw my Turbo on it for a top off when I get home, since the thing won't last past 8PM these days if I don't. I use the Turbo Charger overnight to get a full charge.
    I also use it while watching streaming video so as to not drain the battery since I insist on having the brightness turned way up to enjoy the beautiful screen I paid for, since I'm now required to turn the brightness way down for everything else to get it to last the day.
    But I have had no 'wonkiness' from using the TYLT charger. I find it extremely convenient, and the tilt feature makes it perfect for what I use it for.
    maxman1 likes this.
    09-27-2015 07:42 PM
  3. zen45's Avatar
    I've only used the turbo charger or my computer usb port to charge my droid turbo, but one thing I found out is that there is a difference in the cables I have 3-4 cables that fit the phone . but don't seem to work right , but it seems the cable that came with the phone works different when I plug it into my usb port I can access the files delete stuff brows files with the other cables I cant access the phone !
    10-06-2015 11:10 PM
53 123
  1. Replies: 4
    Last Post: 06-12-2015, 05:45 PM
  2. Phone Battery Life
    By Grifter73 in forum ASUS ZenWatch
    Last Post: 01-13-2015, 07:46 AM
  3. Replies: 4
    Last Post: 01-05-2015, 12:06 PM
  4. Is an S5 able to charge with an S4 charger?
    By salcori2 in forum Ask a Question
    Last Post: 12-22-2014, 05:56 PM
  5. Migrate to new SD card
    By justanumber in forum Samsung Galaxy S5
    Last Post: 12-22-2014, 04:40 PM
