1. Newdroid122's Avatar
    So I just switched over to a droid turbo 64gig from an iPhone (very happy I made the switch). I've had the phone a little over a week now and initially the battery was superb. Lasted close to the 48hours with pretty heavy use(getting acquainted to the new phone, downloading apps etc) these past few days however I can't even get through a day with that same usage. I did download the Nova launcher which I like alot and that doesn't even seem to show up in my battery usage as you can see. So I don't think that's it. Any ideas as to what it can be? Advice? Any help would be greatly appreciated!Why has my battery life declined so rapidly?-screenshot_2014-12-23-18-46-44.jpgWhy has my battery life declined so rapidly?-screenshot_2014-12-23-18-47-16.jpg
    12-23-2014 10:02 PM
  2. D._Manley's Avatar
    A couple of things may be a clue. First, cell signal has been "iffy" with a lot of weak signal & total dropouts. Secondly, your wake time seems a little more than it should (with screen off) at least, to me.
    12-23-2014 10:26 PM
  3. Newdroid122's Avatar
    I did spend a decent amount of time underground on the subway, but still no more than 2 hours. I appreciate the response.
    Any idea on why that would be? I honestly didn't even know how to discect that screen but after your comment that makes a little bit more sense.
    12-23-2014 10:32 PM
  4. Masheen's Avatar
    What is your screen-on time?
    12-24-2014 01:40 AM
  5. doogald's Avatar
    Try removing Nova launcher again and see if battery life is back to normal. It could be Nova, just hidden under android system or Android OS.
    However, I think it's a combination of high screen use and occasional poor signal. The 48 hour promise is for people who hardly use their phones and live near mobile towers and stay within a few feet of a wifi router all day.
    12-24-2014 05:45 AM
  6. Sidharth Tyagi's Avatar
    You can try greenify app which is now available for non rooted devices also. Its hibernate all the apps which runs in the background , its helped me a lot you can give it a shot too. Otherwise i found this article very useful ( sorry m new so i can't post link but you can search on google " etech4u increase battery life").
    12-24-2014 05:54 AM
  7. Newdroid122's Avatar
    Yea I wasn't expecting a full 48hours but was alarming to see it go from close to 2days to less than 1 in just about a week
    I just checked greenify and had almost all my apps running in the background so hopefully that is the cause.
    Thanks for the input
    12-24-2014 09:19 AM
  8. paintdrinkingpete's Avatar
    Highly doubt it's Nova...I've been using Nova Launcher on my Turbo since I got it, and haven't had any issues in that regard (And I've been using Nova on my other Android devices for years).
    Looking at your screenshot, in the 10.5 hours on the graph, there were at least 3 blocks of time where the cell signal was pretty bad and wifi was not connected. Also, your screen time appears to be somewhat substantial. Those 2 things are the top battery life eaters on an otherwise healthy phone.
    If you click on "Screen" (as shown in the right-hand pic with 44% next to it), it should give you a total time of the screen being on...if you post that information here that can help to diagnose.
    10.5 hours on the Turbo battery is a bit shocking, as I don't think I've ever had mine go dead in less than 24 hours, but if, for example, the screen was on for over 5 of those hours and the phone was doing a bunch of other things as well (including searching for signal), that could be normal.
    Frankly, I wouldn't panic...yet. If you've only had the phone for a week or so, you may have just hit heavy day that ran through the battery quicker than normal. Keep an eye on it and see if the battery life doesn't start to improve and level off when it's not being used as much.
    12-24-2014 09:46 AM
  9. Newdroid122's Avatar
    Question about greenify:there's a handful of apps that are consistently showing up on the list to manually hibernate. Is there a way to stop them from automatically restarting?
    12-24-2014 01:25 PM
  10. chasvs's Avatar
    Which charger have you been using? I had been using a Qi charger and got terrible battery life. Switched to only using the Turbo charger and have been getting two days worth of use given my normal routine.
    12-24-2014 03:01 PM
  11. Newdroid122's Avatar
    The turbo charger it came with. I've used greenify and have shut the apps down. Wish I knew how to stop them from automatically restarting.
    I still don't know why it seems to be awake with the screen off but I'm still troubleshooting
    12-25-2014 11:15 AM
  12. jec11718's Avatar
    I turned off my moto gestures that constantly wake it to show the time and notifications. Now it only wakes if you move it. And it takes at least two weeks for a new battery to settle. Mine did almost the exact thing. After it settled, bam great battery life
    DRoID TuRBo this...
    12-25-2014 11:48 AM
  13. doogald's Avatar
    If the phone is playing music, for example, or in the middle of navigation, or on speakerphone dung a call, it will stay awake with the screen off. Also while you are charging.
    Otherwise you have an app in the background holding the phone awake.
    12-25-2014 12:42 PM
  1. Galaxy Note 3 is dead after battery removed from the live phone!
    By Biigii in forum AT&T Samsung Galaxy Note 3
    Last Post: 02-24-2015, 03:12 AM
  2. Is this battery life normal?
    By Tiffianie Perritt in forum HTC One M8
    Last Post: 12-25-2014, 09:22 PM
  3. Battery help
    By Newdroid122 in forum General Help and How To
    Last Post: 12-25-2014, 02:24 AM
  4. How do I get my phone up and running again?
    By Samir Issa in forum General Help and How To
    Last Post: 12-24-2014, 11:57 AM
  5. Replies: 1
    Last Post: 12-24-2014, 12:39 AM
